Thread: Access to washer bottle pipes
  1. Access to washer bottle pipes
    Sep 2008
    Anyone know how I can get at the washer pipes where they connect to the washer bottle on my A4 Avant?
    The cold weather has frozen the rear pipe and as a result it's disconnected itself and washer fluid is pouring on the drive. This happened before and the Audi dealer sorted it under warranty.
    Once I've sorted it there'll be higher strength washer fluid going in there as it seems to be a weakness as soon as the temperature drops.
    Any help much appreciated as my rear screen is pretty mucky.
    John
  2. Re: Access to washer bottle pipes
    Aug 2010
    stone uk
    You just have to take the boot int panel off! once you've got the 4 torx's out, there are about 6 metal clips! they can take a bit of persuading to come out!!
  3. Re: Access to washer bottle pipes
    Sep 2008
    Thanks - but the pipe has disconnected at the front end (I assume at the washer bottle) and not in the boot. Washer fluid is pouring out somewhere behind the front left wheel when the rear washer is used.
  4. Re: Access to washer bottle pipes
    May 2008
    take the front wheel off and remove/lower the wheel arch liner.
  5. Re: Access to washer bottle pipes
    Sep 2008
    Took off the wheel and wheel arch cover and located the disconnected pipe at the top on the bulkhead side. Pushed the two pipes together and cable tied in the hope it might stop it disconnecting again.
    Thanks for the help - saved me a trip to the sdealer.
    John
  1. Washer bottle empty warning when full
    By NickPicks in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-05-2010, 08:15 AM
  2. Please Help Audi A4 Washer Bottle Leak
    By Audichap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2010, 05:04 PM
  3. Please Help '02 Polo washer bottle access
    By Snipey in forum Polo - Derby - Lupo - Fox
    Last Post: 31-01-2010, 10:45 PM
  4. Please Help Washer Fluid Bottle B6 s4
    By s4-matt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-09-2009, 03:29 PM
  5. Help please Re: Rear washer jet.
    By Big_E in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:29 PM
