Thread: Xenon lights retrofit?
  1. Xenon lights retrofit?
    Jeff Lee Guest
    Bought Avant SE new in May and love it. Only regret is not getting Xenon lights - the standard ones are OK but having seen the difference in a friend's car in bad weather (such as today's) I'm wondering whether they can be retrofitted. Any comments/experiences? My dealer is not available at the moment (short-staffed) and will ask them in due course. Thanks.
  2. Re: Xenon lights retrofit?
    May 2008
    Your dealer wont entertain it as it isn't an "approved Audi retrofit". I wouldn't waste a phonecall.
    Its possible but it aint going to be cheap. Budget for approaching £1k if you do it all yourself. Lots more if you have to pay labour charges as well.
    Dont forget that in addition to the lights (and ballast units) you need to add the auto-levelling and headlight wash system to make it legal. www.kufatec.de will sell some of the wiring you need, Sourcing the lights themselves isnt easy as they are (unsurprisingly) very expensive from Auid themselves.
  3. Re: Xenon lights retrofit?
    Feb 2010
    Liverpool
    Have to admit that it's the first car I've owned thats had them fitted. It took ages to convince both me and the wife to stop thinking that we had main beam switched on everywhere we went. These should be standard on all new cars.
  4. Re: Xenon lights retrofit?
    Oct 2010
    Bristol UK
    And the LED's are a added bonus.
  5. Re: Xenon lights retrofit?
    It's a common myth that to make your car legal you have to have auto levelling and headlamp was - not true....... You need both to register a brand new car with xenons (needed to get a European Certificate of Conformity) but once the car's on the road there is no such requirement.
    On my older A4 I had a retro fit xenon kit from HIDs 4 U and that was good and they are good value. I'd recommend with one of these systems paying someone to fit it as they will be better equipped to fit the relays etc required to overcome the bulb warning systems. Normal would be about £100 for the kit and then allow an hour or two of labour.
    I'd forget about trying to retro fit the genuine item headlamps - my local Audi dealer have quoted people before for the job and it's about £2000.
  6. Re: Xenon lights retrofit?
    May 2008
    Quote Originally Posted by steve1234 View Post
    I've fitted them myself to previous cars so I arent preaching about legalities but the DfT say this
    http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
    I believe work is in progress to make aftermarket HID that don't comply with the above to be MOT failures.
  1. DRLs, is this setup possible?
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 08:37 AM
  2. Question Xenon Retrofit - VAG Coding
    By nick666 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-03-2010, 11:03 AM
  3. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  4. Golf GT Xenon Lights
    By Alistair101 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-11-2007, 09:27 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
