Thread: Coolant Volume or Capacity
  1. Coolant Volume or Capacity
    Mar 2008
    High Wycombe
    My turn to ask a newbie ish question...
    I've just tested the coolant in both cars by taking a sample and freezing it, so neither of my Audis are protected below -18 degrees.
    The A3 was easy to find out how much I need - 5 litres according to Haynes and Elsa.
    The A6 is a bit more complicated. The only volume that elsa says is "fill with at least 10 litres". but says to add 6 litres of G12 to go from zero protection to -35.
    So, what's the coolant volume for a 2.4 V6 AML engine A6 Avant? Is it 12 litres? That seems like an awful lot compared to the 5 litres the 4 cylinder engines have.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  2. Re: Coolant Volume or Capacity
    The 10 ltrs is the content of the filling reservior not your header tank. You will be able to fill the engine with close to 7 Ltrs. I would fill with 4 Ltrs of G12+ then add De-min water to fill her up. Getting the air out of this engine is not easy. Regards Peter
  3. Re: Coolant Volume or Capacity
    Mar 2008
    High Wycombe
    Thanks Peter D. I've read the air bleeding instructions! I'm thinking it might be easier to drain a litre out, then add a litre, then drain a litre etc until I'm happy there's enough G12++ in there. That would avoid emptying the header tank and getting air in there.
    I ought to do it properly though, as the liquid is a light brownish pink colour, so I ought to do it properly - flush it and follow the bleeding instructions.
    Thanks for your help.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. engine coolant capacity golf 1.9tdi sport
    By ccs in forum Golf MK5 - 2004 - 2009
    Last Post: 01-09-2010, 10:46 PM
  3. What is the safest way to dispose of old G12 Coolant ?
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2008, 03:38 PM
  4. Coolant system renewal!
    By Pernicitus in forum Golf MK3 - 1993 - 1999
    Last Post: 22-10-2007, 11:39 PM
  5. polo coolant volume
    By s8fcc in forum Polo - Derby - Lupo - Fox
    Last Post: 22-09-2006, 04:24 PM
