Thread: High Air Inlet Temp. What should it be
Results 1 to 10 of 18
  1. High Air Inlet Temp. What should it be
    Dec 2008
    Audi TT BAM engine conversions running a standard engine managment, cold air intake, high flow 100cpi cat.
    I'm currently suffering with poor fuel efficency not able to achieve more than 30mpg. I know this is not BAD but surely I can do better.
    I have logged in using Vag Com and there is a returning fault code with efficency below threshold but the fuel trims are well within limits at -7% and +3%. Engine runs smoothly throughout rev range.
    Engine coolant temps run at 90-100 degC
    Now I believe the problem lies with the air inlet temp, even under low boost pressures the air temp soon gets up to 40degC, under higher boost temps get up over 70degC.
    I do have plans are to fit a front mount intercooler but I would be grateful if someone could educate me a little as to what the air inlet temps should be.
    Many thanks
  2. Re: High Air Inlet Temp. What should it be
    135 Post(s)
    2036 Post(s)
    What fault code numbers are you getting and in which measuring block and field are you reading the temperature?
  3. Re: High Air Inlet Temp. What should it be
    Dec 2008
    Hi Crasher
    Thanks for taking a look. This error code keeps coming back not straight away but 10mins or so. I'm sure this is down to the 100cpi cat but would this effect the fuel ecconomy.
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 8N0 906 018 CB
    Component and/or Version: 1.8L R4/5VT G 0003
    Software Coding: 10710
    Work Shop Code: WSC 12341
    Additional Info: TRUZZZ8N541021076 AUZ5Z0CD295007
    VCID: 73EE04D46BC7
    1 Fault Found:
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
    P0420 - 35-00 - -
    Readiness: 0000 0000
    For obtaining the Intake Air Temp I have looked in group 004 column 4
    For fuel trim group 032.
    At the moment I havn't tried recording a graph of the intake air temp but I'll let you know how I get on.
  4. Re: High Air Inlet Temp. What should it be
    135 Post(s)
    2036 Post(s)
    I wouldn’t think that the temp reading you are seeing is too high, that sensor is in the inlet manifold after all. Your cat seems to be of low efficiency.
  5. Re: High Air Inlet Temp. What should it be
    Dec 2008
    [IMG]file:///C:/DOCUME%7E1/MALCOL%7E1/LOCALS%7E1/Temp/moz-screenshot-3.png[/IMG]Well I managed to get a graph, please see attachment
    The ambient temp was -1degC.
    Intel air temp spiked over 40degC.
    Exhaust gas temp spiked over 680degC
    Got any ideas??
  6. Re: High Air Inlet Temp. What should it be
    135 Post(s)
    2036 Post(s)
    Looks OK to me.
  7. Re: High Air Inlet Temp. What should it be
    Dec 2008
    I've been told that the engine managment system when it see's temperatures getting to high, over feeds/increases the amount of fuel entering the combustion chamber in an attempt to control/reduce the temp and protect the engine.
    Is this true??
    If so, can the inlet air temp activate this protection system??
    Many thanks for all your help.
  8. Re: High Air Inlet Temp. What should it be
    135 Post(s)
    2036 Post(s)
    I have to admit to not being completely aware of the exact parameters in the software, I leave that to geeky types but yes, extremely high inlet temps are not good and are often dealt with by adding fuel and puling back the timing but your peak temps do not seem that high to me.
  9. Re: High Air Inlet Temp. What should it be
    Dec 2008
    I have seen in this thread that there is mention of the thermal protection being related to exhaust gas temperature. (bottom of thread)
    http://uk-audis.net/forums/t/2001.aspx
    With this in mind and looking at the profiles plotted by my inlet air temperature and the cat temperature its no surprise to see the two have similar profiles.
    It's no surprise to see this on the log that I got, but I would like to point out the fact that the ambient air temp was -1 degC. What if the ambient air temp was 15-20 degC, I can only imagine the exhaust gas temp would go over 800degC.
    I think I'll try talking one of my work colleges into profiling his Golf GTI's inlet air and cat temps, then I would have somthing to compair mine to.
    Wish me luck.
  10. Re: High Air Inlet Temp. What should it be
    135 Post(s)
    2036 Post(s)
    You have an EGT sensor on your engine.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. MK4 Air Con Saga & Fix
    By NinjaNutter in forum Golf MK4 - 1999 - 2004
    Last Post: 10-10-2010, 08:31 PM
  3. Please Help Heating Issue with 2000 Passat no warm air at high blower speed
    By mafia666 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2010, 08:46 PM
  4. Question air temp unit??
    By Inspector Beetle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-06-2009, 11:39 AM
  5. IAT Inlet Air Temp, Where is it???!?!?!?!!??!
    By lupen412 in forum 80 - 90
    Last Post: 07-05-2009, 11:13 PM
