Thread: struggled to start this morning
  1. struggled to start this morning
    Nov 2010
    Helensburgh
    hi all, we had some snow yesterday and it was minus temperatures most of the weekend. the car was running fine and starting fine friday, but when i went to start this morning it struggled to fire.
    the starter turns fine, so i dont think its the battery, it just sounded like it was running on two cylinders, then chugged for about ten seconds, then kicked in and started running if not a little chuggy when it was cold.
    is there anything common i should be looking at? its a 1.6 petrol, does it have coilpacks or a dizzy cap?
  2. Re: struggled to start this morning
    134 Post(s)
    2022 Post(s)
    Which year and engine code? Some of those have a dist cap that is absolutely evil to get at. Your problem may be a faulty coolant temperature sender so I suggest you start by getting someone to give it a fault code read.
  3. Re: struggled to start this morning
    Nov 2010
    Helensburgh
    its a 1.6 adp 8v.
    just been out and tried it again after driving to work and it getting to temp, and it started first time with no problems, so i think its damp or cold getting to a component rather than something properly failed. think ill replace the plugs out of routine anyway.
    just waiting for my vagcom to turn up to read the codes.
  4. Re: struggled to start this morning
    134 Post(s)
    2022 Post(s)
    The distributor cap on an ADP engine is awful to get and so is not often changed.
  1. Will not start after rain
    By keithmcd in forum Golf MK3 - 1993 - 1999
    Last Post: 20-10-2010, 07:58 AM
  2. help please, car wont start
    By mk3 tdi in forum Golf MK4 - 1999 - 2004
    Last Post: 08-10-2010, 06:42 PM
  3. Question She wont start First Time! :(
    By gtflyrob in forum Golf MK3 - 1993 - 1999
    Last Post: 26-06-2009, 10:17 AM
  4. Why wont it start?? Pls help!! (Golf mk3)
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 11-03-2008, 09:22 PM
  5. Passat wont start!
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2008, 01:15 PM
