Thread: Front right ABS sensor replacement
  1. Front right ABS sensor replacement
    Hi guys just asking for a bit of advice im about to replace the front right abs sensor on my 2000 passat (1.9 tdi afn engine),but the wiring is looking a bit tricky ,i can get the sensor out but where does the connection go to that goes up the inner wing and into the bulkhead underneath a big black box do i need to remove this box so i can connect the new sensor or does it connect somewhere else,thanks for any help.
  2. Re: Front right ABS sensor replacement
    May 2010
    Devon England
    there should be a plug, if its not on the sensor, follow the wire as you have done until you find it, i may be wrong but i thought the plug as on the sensor itself mate
  3. Re: Front right ABS sensor replacement
    i thanks for that but there is a plug on the lead that goes to the brake caliper and the abs sensor does not have a plug on the end it is hard wired to the sensor with a lead on it about 700mm long which has a plug on the end that goes goes up into the bulk head,thanks
  1. ABS Warning light etc
    By churchy5 in forum A2
    Last Post: 21-04-2010, 11:32 AM
  2. Please Help Front Left ABS Speed Sensor
    By idealsam in forum Polo - Derby - Lupo - Fox
    Last Post: 30-07-2009, 09:57 AM
  3. Please Help front & rear wipers and ABS failure light
    By lpg boy in forum Early Passat Forum - Pre 97
    Last Post: 29-07-2009, 09:43 PM
  4. A4 B5 2.5 Tdi Saloon - ABS system Bleeding ?
    By kevmayer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2009, 05:30 PM
  5. ABS light Issue
    By gnasher in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-01-2008, 08:32 PM
