Thread: electric adjustable steering column fault
  1. electric adjustable steering column fault
    Sep 2008
    Cheshunt. Hertfordshire
    i have 2007 3.0 tdi, the problem being the steering column goes in and out, but not up and down, VCDS brings up no fault code,
    How can I investigate this further guys?
    is there a test in VCDS I can do?( full license)
    thanks
  2. Re: electric adjustable steering column fault
    I have a brand new cowelling with switch and control unit. In dark grey / black & never fitted Bought for mine but the problem was in fact a trapped cable behind the column. let me know if you want it. Yours for £40 + postage which is less than half what I paid from Audi. Saves me experiencing the traumas of Ebay!
  3. Re: electric adjustable steering column fault
    Sep 2008
    if its that ill have it off you, how do i know if its that though? or is that all it can be
  4. Re: electric adjustable steering column fault
    May 2007
    knee deep in clunge
    14 Post(s)
    you need to simply re adapt/teach in basic setting via vag com
  5. Re: electric adjustable steering column fault
    Sep 2008
    i cant find a controller for steering column electrics, which one is it?
  6. Re: electric adjustable steering column fault
    May 2007
    knee deep in clunge
    14 Post(s)
    address 09 central electrics
    Basic Setting
    Steering Column Adjustment
    Prerequisites:
    * Steering Column or the Central Electronics Control Module (J519) have been replaced.
    * Approach all 4 end positions (up, down, forward, back).
    [Select]
    [09 - Central Electronics]
    [Basic Settings - 04]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The adjustment should now be learned.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
  7. Re: electric adjustable steering column fault
    Sep 2008
    thanks jam man, wont be needing part, done what a8 tech said, all working.
    top job, you the man.
    i had quite a lot of fault codes come up, ill start new thread later, hope you may help.
  1. Audi A3 2.0 TDI (2005/55) Vagco help
    By brumster in forum VCDS - Help Requests
    Last Post: 09-02-2011, 06:53 PM
  2. Possible battery issue ??
    By Tay in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-12-2010, 07:45 PM
  3. Audi A6 VagCom Scan Results.
    By cwilding in forum VCDS - Help Requests
    Last Post: 19-11-2010, 10:19 PM
  4. Help please with problem on my A6 (flashing Glowplug light)
    By oDUTCHYo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-08-2010, 10:45 PM
  5. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
