Thread: Fuel Level Sensor (G) - Open or Short to Plus
  1. Fuel Level Sensor (G) - Open or Short to Plus
    Mar 2010
    My fuel guage isn't working at all. The gauge is always at resting point (ie, completely empty). Error message on MFD is "Fuel system malfunction".
    Car runs perfectly well however, just no fuel indicator.
    VCDS has found this fault code in the instrument cluster:
    Does anyone have a description of the pins on the back of the instrument cluster so I can check them out? I don't fancy guessing with the 32 cables that are in there!
    Car is a 2009 Audi A3.
    I don't fancy taking it to the dealer - wheres the fun in that?
  2. Re: Fuel Level Sensor (G) - Open or Short to Plus
    Mar 2010
    harlow-essex
    Maybe you should chech the 4 wires that are connected to the lift pump in the fuel tank located under the rear seats.
    Good luck
    P.s.I see that u got a 2009 audi,my car is a golf but the location should be similar...that s easier than going to the ********,Check the resistance of the wires.
  1. 01441 low fuel level sensor
    By philfingers in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-03-2010, 12:09 AM
  2. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  3. 2.8 Quattro Fuel Tank Level Sensor
    By SHAZA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-03-2008, 02:31 PM
  4. Power Problem - 2001 GT TDI 110 Fuel or Turbo?
    By Don-e in forum Archive posts
    Last Post: 07-11-2005, 10:59 AM
