Thread: Instrument Lighting
  1. Question Instrument Lighting
    Oct 2009
    Stafford
    Hi all, I previously owned an A4 B5 2.5TDi Avant which had the instrument lighting permanently on, I now own a Seat Exeo ST 2.0 TDi which is based on the A4 B7 platform and uses the dasboard of the A4 Cabriolet. The instrument lighting is only on with the lights in the Exeo, is that the same on the Audi B7? I do find in certain conditions, that the instruments are not easy to see. Just curious to know if this is a Seat idea or did the Audi have the same....Julian
  2. Re: Instrument Lighting
    Feb 2010
    Hazlemere
    Hi Julian,
    I've got an 05 A4 B7 and I can confirm the Dash lights are only on when side lights on.
    I have to agree I normally put my side lights on all the time as I find I sometimes can't see some of the dash.
    The B6 and B7 are almost the same car so I don't know if the dash lights can be modified to stay on. . . .
    Mark.
  3. Re: Instrument Lighting
    Norwich
    In the A4 I believe the speedo lighting works so as that they are on all the time, but dim when in dark conditions to remind you to turn your lights on.
    I only say this as when driving through tunnels, they stay on but quickly dim although the red needle stays lit.
  4. Re: Instrument Lighting
    Dec 2007
    you can change it with vcds
    mine was off unless lights were on
    iv set mine so the needles are on all the time
  5. Re: Instrument Lighting
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Mines as KodKod 84, on during day, dims to `OFF` when it gets dark. 06 TDI.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: Instrument Lighting
    May 2007
    knee deep in clunge
    14 Post(s)
    two options
    change the adaption value for needles and instrument lighting in address 17 channel 19
    code the central electrics for Nordic region, this will illuminate the clocks and activate the side lights with ignition on and light switch off
    My B6 is set to Nordic so my side lights are always on in winter and then I recode for uk in summer
  1. Instrument cluster lighting
    By NikB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-08-2010, 06:27 PM
  2. Instrument Pack Lighting
    By jammy86 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-11-2009, 07:07 PM
  3. instrument / climate control lighting bright then dimming
    By squire77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2009, 10:37 AM
  4. Instrument Cluster Lighting.
    By Hippogriff in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2009, 11:18 AM
  5. Instrument Lighting
    By pmnpmn in forum Golf MK6 - 2009 - 2013
    Last Post: 12-07-2009, 12:14 AM
