Thread: Auto gearbox sticking in 'park'
Results 1 to 10 of 12
  1. Unhappy Auto gearbox sticking in 'park'
    Nov 2010
    Ilkley
    Two days ago we bought a 1.9TDI Passat Auto and have twice had a problem moving it out of park. Once out of park it seems fine and runs well but we previously had the same car (2 years older) without any gearbox issues at all so I know how it should feel. Any suggestions as we need to contact the dealer soon if it is likely to be a big problem? Thanks
  2. Re: Auto gearbox sticking in 'park'
    Jul 2010
    Brighton
    i've had the same problem with mine too, but as yet not found out what it is, although i have found that if you apply the handbrake first lift off the footbrake with car in neutral, then put car in park as normal it doesn't do it, so i think it has something to do with the gearbox lock
  3. Re: Auto gearbox sticking in 'park'
    Jun 2006
    UK, Mids
    If it happens on an incline, the handbrake is probably not holding, and putting a strain on the transmission dog. Whatever it is, you need to get to the bottom of it before it ruins it.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Auto gearbox sticking in 'park'
    Jul 2010
    Brighton
    Quote Originally Posted by snapdragon View Post
    i'm getting a fluid & filter change done as i don't believe it lasts forever even though it's "sealed for life" see if it's better after that
  5. Re: Auto gearbox sticking in 'park'
    Jun 2006
    UK, Mids
    Very good thing to do, but that won't have any effect on this.
    When you put it in P, what effectively happens is a peg goes into a hole.
    If you don't have the car held by the hand brake, the peg get's pinched and so is hard to pull out. There was one case on the US forum where a man used P to hold the front wheel while he undid the nut and it snapped off, I also remember years ago on a Vauxhall forum a man has his snap off when someone hit his car in the carpark.
  6. Re: Auto gearbox sticking in 'park'
    Nov 2010
    Ilkley
    Hi there, thanks to all of you have replied to my 'help' request. I am going to try replacing the sensor under the footbrake as I have been told that could be a likely cause for this problem. There is apparently also a sensor under the transmission lever which I can then try if this doesn't work. The VW mechanic said that it could be slipping on parking and just leaving the cogs slightly out occasionally and that this is quite a common thing with these gearboxes. I will also try the suggestion of putting handbrake on while in neutral etc. A few things to try and hopefully one of them will sort the problem as the car is great apart from that . Thanks again.
  7. Re: Auto gearbox sticking in 'park'
    Jul 2010
    Brighton
    did you get anywhere with this? would be great to find out if there is a fix for it
  8. Re: Auto gearbox sticking in 'park'
    Nov 2010
    Ilkley
    Not yet, I'm afraid - the snow got in the way a bit but I am going to change the switch under the brake pedal (£30) and see if that makes a difference. I will also ask garage to oil the cogs in the gearbox, which was another sensible suggestion from a mechanic. After that I will post on here if it has had any effect. Thanks for the interest.
  9. Re: Auto gearbox sticking in 'park'
    Jul 2010
    Brighton
    ok well keep me informed how you get on , i am really interested if any of this solves the problem thanks for your reply
  10. Re: Auto gearbox sticking in 'park'
    Nov 2010
    Ilkley
    Just wanted to let you know that I had the foot switch changed and it has not made any difference. Now intend to get it back into the garage for investigations which is a bit irritating. I don't think it's anything major as the gearbox works fine apart from this sticking thing! Will keep you posted if I ever find out what it is.
  1. VW Sharan VR6 (99) Auto gearbox problem
    By bluemozzer in forum Touran - Sharan - Caravelle
    Last Post: 01-01-2013, 11:53 AM
  2. Can i swap my auto gearbox and ecu with another model B5?
    By eddy7679 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-09-2009, 03:51 PM
  3. Gearbox oil level
    By mowjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 13-08-2009, 01:11 AM
  4. lazy auto gearbox when cold
    By armagan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 11:49 PM
