Thread: Wireless network issue
Results 1 to 10 of 11
  1. Wireless network issue
    Apr 2007
    Hampshire
    Been using a Linksys wireless router since January with my laptop which has only a few times not wanted to work, a quick re-set & all was ok again. However, went out to the car the other night after getting my vag-com cable & whilst I was there made use of someone elses unsecured network to log onto the net as my router was out of range. Naughty I know but i'll repent another day! Ever since then I havent been able to log onto my home network whatever I do, I keep getting "limited or no connectivity" show up. Tried the usual re-set the router options, the network key the laptop is using to access the router is correct....................im a little lost & virging on uninstalling the router & re-installing from scratch. Anyone got any ideas? Thanks.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
    BROWN_OWL Guest
    have you tried removing the unsecured network form your list of available wireless networks.Also try going into network connections, properties, LAN settings and ensuring that it is set to obtain network ip automatcally. Try entering the network key in again
    BROWN_OWL Guest
    follow this if unsure. open network connections. right click over wireless connection, click properties. scroll down to tcp/ip and click once. then properties. select obtain ip automatically. ok. then wirelessnetwork tab and remove the network you "borrowed" should be ok!!
    May 2007
    Scotland
    That's your punishment.
    Apr 2007
    Hampshire
    Yeah, i've removed all other networks from the prefered networks list apart from my network & its set to automatic, and i've manually re-entered the key code. Anything else I can try?
    BROWN_OWL Guest
    try removing all connections and rebuoilding it again. by searchin wireless networks. a pain i no but it does work (sometimes)
    Apr 2007
    Hampshire
    Quote Originally Posted by Veedubber View Post
    I know, but im certainly not the 1st to do it nor the last!!
  1. Cluster Issue
    By stevepil in forum Audi A3 - Archive Topics
    Last Post: 01-07-2007, 03:29 PM
  2. Air Con Issue
    By Audi Eire in forum Audi A3 - Archive Topics
    Last Post: 13-06-2007, 05:19 PM
  3. Aircon issue
    By nickynibbles in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2007, 03:24 PM
  4. Polo GTI Sat nav issue
    By PoloGTI2103 in forum Polo - Derby - Lupo - Fox
    Last Post: 20-03-2007, 02:02 PM
  5. yet another issue
    By ktscarlet in forum Chat - Anything with wheels
    Last Post: 30-10-2006, 02:58 PM
