Thread: B8 Avant tailgate doesn't open by the handle
  1. B8 Avant tailgate doesn't open by the handle
    May 2007
    I'm not sure if I'm doing something wrong here, but the handle on the tailgate of my avant doesn't do anything... I can only open the boot using the key.
    I've tried both settings in the Car Setup menu, nothing changes. The only time the handle works is if the tailgate is partially closed (eg: if it's not been closed down hard enough), then it works to open it again.
    Is this how it's meant to be or shall I add it to my dealer-query list?
  2. Re: B8 Avant tailgate doesn't open by the handle
    Apr 2010
    Salisbury
    It sounds like it's locked? Within the setup I take it you have set it to keep the boot unlocked and that is making no difference?
    I have mine locked at all times and I have to use the key to open/unlock the boot, followed by the handle... If it is always unlocked then the boot will open by the handle alone.
    If it isn't doing as mine does above then maybe worth a trip to the dealer...
    Hope this helps!?
    A4 2.0TDI Quattro S-Line Special Edition (B&O & 19's) with S-Line suspension, Ibis White, Black Styling Pack, Privacy Glass and Alcantara with Piano black inlays
  3. Re: B8 Avant tailgate doesn't open by the handle
    May 2007
    knee deep in clunge
    14 Post(s)
    unlock the dead lock postion and retry
  4. Re: B8 Avant tailgate doesn't open by the handle
    May 2007
    Quote Originally Posted by a8 tech View Post
    How do I do that?
  5. Re: B8 Avant tailgate doesn't open by the handle
    May 2007
    Quote Originally Posted by dan172 View Post
    Hope this helps!?
    The rest of the car isn't locked. I have the car set to unlock the drivers door on the first click, the rest of the doors on the second... but the boot still doesn't operate by the handle.
    Doesn't sound like it's behaving like you describe... could be a dealer trip. Thanks.
  1. Tailgate wont open
    By terence6r in forum Golf MK4 - 1999 - 2004
    Last Post: 08-10-2010, 11:58 AM
  2. A6 Avant Tailgate lever
    By fenboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-12-2009, 12:15 PM
  3. Tailgate Unlock problems- need a definitive answer
    By gav_j_crompton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-12-2008, 06:22 PM
  4. Avant - Tailgate Water Ingress
    By deelee in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-05-2008, 01:32 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
