Thread: oil pressure a4 2.0
Results 1 to 10 of 10
  1. oil pressure a4 2.0
    Feb 2010
    Norfolk uk
    hi,ca someone tel me what oil pressure my engine is suposed to have??the car is an audi a4 2.0 engine code alt(2001) i think my mecanic is trying to rip me of as he did an oil presure test and told me i have 1.5 bar(21.7psi) when i should be haveing 7bar(101.5psi) at idle,i dom t have a warning light on the car or anything,he did the test because the car has a slight ratle on idle,now he is telling me that the work is going to cost me 700£ plus another 700 for an oil pump wich he es recomending i change what do you guys think
  2. Re: oil pressure a4 2.0
    Feb 2010
    Norfolk uk
    nobody,antthing??!!??
  3. Re: oil pressure a4 2.0
    Your mechanic is talking out of his hat.
    The minimum oil pressure at idiling speed should be 2.0 Bar,
    at 2000 Rpm it should be between 2.7 and 4.5 Bar.
    At 1.5 bar you are down on oil pressure slightly. Just because the oil light isn't on doesn't mean you don't have a problem. The oil pressure switch could be faulty.
    It could be the strainer on the pick up pipe is blocked. I know the 1.8T engines suffer from this badly, not sure about 2.0.
    I would take it somewhere else for a second opinion.
  4. Re: oil pressure a4 2.0
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    If you were supposed to have 7 bar you would have problems keeping the oil IN the engine LOL!! He`s got his info wrong anyway!
    Alan.
    VW T6 150 DSG Camper £££
  5. Re: oil pressure a4 2.0
    Feb 2010
    Norfolk uk
    I went to colect the car today,they keept saying that is should be 7bar when the engine is hot and idling,the oil pressure switch faulty I am guessing it would show on a vag com scan which it dosen t,the mechanic are actualy an audi vw specialist just outside Norwich,I was talking to a audi mechanic from a different country,he was saying 1.5bar is just fine and I should worry if it drops below 1bar,any way I going to leaveit for now,worst case scenario recon engine 1200£ fitted +warranty,no way I am going to spend 700£on the oil pump and another 700 for them to clean my engine and fit the pump
    Thanks for the reply s
  6. Re: oil pressure a4 2.0
    A faulty oil pressure switch wouldn't neccessarily show in a fault code scan, although it is likely to.
    1.5 Bar is below spec but if an Audi mech. thinks that is ok then leave it. Certainly wouldn't be fitting a new oil pump.
    The garage may well be a VAG Specilist but it sounds like the guy you got is a blithering idiot. 7 Bar at idle is mental. As Alan has said above your enigne would struggle to handle that pressure.
    I would suggest to him he reads the relevant page in ElsaWin for your engine. He is talking pony.
  7. Re: oil pressure a4 2.0
    131 Post(s)
    1973 Post(s)
    The idle pressure is slightly low but I would not worry unduly.
    Minimum oil pressure at idling speed: 2.0 bar
    Minimum oil pressure at 2000 rpm: 2.7 ... 4.5 bar.
  8. Re: oil pressure a4 2.0
    Feb 2010
    Norfolk uk
    Thank you for the reply,i changed My oil And filter last week I put in Castrol slx professional 5w30,I will be change it again in 3000 miles just to be on the safe side and see how I get on,the garge gave the diagnostic after they did the presure test they did not take the roker cover of or anything,did the test then called me say I will be having 1400£ bill if they fix it,that s not right,is it?
  9. Re: oil pressure a4 2.0
    Quote Originally Posted by laur View Post
    No its not right. If they don't even know (or bother to look up) the correct pressure values then how can they be so sure the pump is faulty. Bunch of chancers in my opinion
  10. Re: oil pressure a4 2.0
    Feb 2010
    Norfolk uk
    Many thanks guys,the Reply s make me feel alot better,just to add some more info about the car:mileage 130000,the garage won t be getting my business in the future!
    Again many thanks
  1. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  2. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
