Thread: Golf TDI hesitation, then complete power loss on motorway
  1. Re: Golf TDI hesitation, then complete power loss on motorway
    Jan 2008
    nottinghamshire
    sounds like head gasket and overboost problem same as me, same engine code?
    not sure why it dies on you though??
  2. Re: Golf TDI hesitation, then complete power loss on motorway
    Warrington
    overboost problem?
  3. Re: Golf TDI hesitation, then complete power loss on motorway
    Jan 2008
    nottinghamshire
    yer loss of power on the motorway, probs a overboost problem caused mainly by dirty turbo vanes, chucks it into limp mode
    thats a common problem too along with the head gasket
  4. Re: Golf TDI hesitation, then complete power loss on motorway
    Pembrokeshire
    22 Post(s)
    a code read, thats what you need first. it could be the turbo vanes, but doesnt sound like it to me. get a code read done and post the results. incidentally, after spending all that money increasing the power, why have you put a new cat on it, rather than a decat pipe, which is much cheaper.
  5. Re: Golf TDI hesitation, then complete power loss on motorway
    Warrington
    Thanks for the responses gents.
    Got the RAC bloke to read the fault codes, came back 'no faults found'. - Would I be right in assuming that this rules out sensor faults? (MAP/MAF)
    Yeah, with hindsight should have gone with the de-cat pipe.
    Don't think this was limp mode to be honest, at first it felt like fuel starvation. But for it to start again 20 mins later and rev up fine, can see why the RAC bloke suggested exhaust problem?? Not sure if clogged turbo vanes would cause the engine to die, and not start up again. - Will have a play with the control arm this weekend and see if they're free.
    Have put some k-seal in so will monitor coolant level over next few days.
    Going to take egr and inlet monifold off when i get a minute and give a thorough de-gunking.
  6. Re: Golf TDI hesitation, then complete power loss on motorway
    Warrington
    Hi folks,
    dug out my OBD2 lead and thought I'd check the fault codes myself,
    turns out there is a code after all:
    17958 - Charge pressure: control deviation
    P1550 - 11 - 00 - Control limit not reached
    any one come across this before?
  1. Please Help Golf MK3 TDI 1996 power loss over 60mph
    By thecableguy12 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-09-2009, 12:41 PM
  2. Please Help 2002 Golf TDI 130 Loss of power
    By karsen in forum New Member Introductions
    Last Post: 31-08-2009, 12:47 AM
  3. golf tdi power loss at 70mph
    By justin@justinwa in forum Archive posts
    Last Post: 12-11-2007, 08:48 PM
  4. Golf TDI Mk3 loss of power
    By Mark Scruby in forum New Member Introductions
    Last Post: 31-08-2007, 10:11 AM
  5. Golf TDI Power Loss
    By donnytella in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-07-2007, 10:31 AM
