Thread: tuning box gremlins?
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
  1. tuning box gremlins?
    cheshire
    Just joined today maybe i can get some pointers on a problem ?
    Have a mk iv tdi 115 recently fitted with a "tuning box" no obvious problems prior to fitting.After fitting i now find that when reaching a certain speed in fifth or sixth gear what i assume is limp mode is activated.
    (marked loss of power)
    Switching the ignition off/on clears the fault and full power is returned.
    This is the second unit i have tried so assume it is a fault on my car?
    Tech. people at manufacturer suspect turbo over boost.
    Is limp mode being activated because of the power increase? no loss of power is evident in standard trim at any speed.
    From searching through the threads a split/punctured hose could be responsible any other possibilities?
    May 2007
    Birmingham
    Is the tuning box a well branded one or is it one off ebay or like?
    TRUST ME! MY THINGS ALWAYS WORK (SOMETIMES)
    ok, i might be being a bit blunt here, but had i fitted something to my car and then my car became faulty... guess what id do first, thats right, take the part off.
    get the tuning box off, first of all. (i can only assume it is a cheapy of eBay? )
    next thing to do , is check all hoses for boost leaks, listen for any excess air at idle, you could have something as simple as a leaky boost pipe, the braided ones.
    there is the slim chance that your turbo could be clogged up, the vanes are sticking or the vane actuator could be sticking, but id go with the first few suggestions first....
    May 2007
    Birmingham
    Quote Originally Posted by eshrules View Post
    AMEN TO THAT!
    cheshire
    Blunts ok.....Assumptions not.
    The unit is branded (£380) not off e-bay!!
    It has been returned for testing and found to be ok.
    Its not going back on the car until i find out what triggered "limp mode" your advice will hopefully be useful in pinpointing the problem.
    Is this similair to the type of tuning box i bought from ebay?
    Paid around £30 for it and was slightly jubious about fitting it but judjing by the positive feedback and the knowledge of the seller i thought id give it a go!
    Anyway wacked it on and the car was a bag of *****, despite having eratic revs in idle, a flat spot a thousand miles long the car would'nt even go! took the <removed> off immediately and tossed it in the bin.
    How can these people sell these pieces of <removed> and blatently lie?
    Last edited by Sam; 23-06-2007 at 08:51 AM. Reason: There are other ways of expressing disgust - explore them please
    cheshire
    Think not
    Been totally happy with the "box" no flat spots ,increased torque,smooth power band, then it hits 104 (allegedly) and the limp modde kicks in ....bummer! Having a diagnostic check/service tues hope to get it sorted.
    cheers
  8. Smile tuning box
    SCARBOROUGH/GARAGE LOCATED IN PICKERING
    inside your potentiometer/variable resistor casing,sorry tuning box casing there is generaly a screw,turn it anti clockwise a little then test drive,repeat this till your car stops kicking limp mode in,even fancy van aaken boxes can be adjusted the same,ive done this to a few customers cars with same problems.Cheers simon
    Quote Originally Posted by julianm View Post
    Think not
    cheers
    Apr 2007
    Cambs
    Quote Originally Posted by Gee View Post
    Paid around &#163;30 for it and was slightly jubious about fitting it but judjing by the positive feedback and the knowledge of the seller i thought id give it a go!
    Because people still buy them............
    Jim Morrison - "Expose yourself to your deepest fear, after that fear has no power, and the fear of freedom shrinks and vanishes. You are free."
    we are so used to seeing this stupid resistor 'tuning boxes' popping up here that we make assumptions now. fair play to you if it is a 'proper' tuning box, although i still have reservations about putting a tuning box on my car that has not been tested on my car.
    one thing you have to bear in mind is that these will contain standard maps for the golf mk4 1.9 tdi and whichever engine it has been applied to. it will not have been tested nor adapted to any of your own cars 'quirks' as such, it can cause issues.
    i think the comment above about adjusting it will be reducing the level of boost being generated, this could be the cause of the limp mode. you have to remember, you will not always see an immediate effect when a problematic part is fitted.
    eg K&N oil panel filters, these are well known to foul your MAF, but you would not see this for perhaps a few 1000 miles.
    you dont say if you have tried running the car without the tuning box, to see if it still enters limpmode, perhaps this could be tried?
    i think the diagnostic is likely to simply show an overboost situation, which we have already established but i am doubtful as to any other part being faulty, id seriously consider whether the tuning box you have is having a positive effect on your car.
  1. Tuning 1.8t
    By gav2612 in forum Archive posts
    Last Post: 07-05-2007, 05:11 PM
  2. Tuning GT TDI 150
    By carraider in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-03-2007, 07:37 PM
  3. Tuning Tdi 150
    By BoraTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 26-01-2007, 08:03 PM
  4. Tuning for TD?
    By Fourbears in forum Archive posts
    Last Post: 16-01-2007, 09:43 AM
