Thread: BKD 3rd turbo failure, HELP!!!
  1. BKD 3rd turbo failure, HELP!!!
    Dec 2009
    london
    I have a 2004 audi A3 with the BKD engine and heres my story so far
    I originally had the first failure a year ago whereby the turbo split in have near the webbing on the compressor side and pumped all the oil into my cylinders causing a bent rod, Took it to a mechanic who diagnosed the failure but the RAC warranty guys said we filled the cylinder with oil ourselves and refused to pay after having a few inspections.
    Sucks but got a new engine fitted, with a turbo and a new EGR valve which proceeds to fail also and got that fixed under warranty from the engine supplier.
    A few months ago the turbo fails again as I started to hear a whining sound so I replaced the turbo.
    The turbo fails again last week and I am at a loss now.
    The last time I had a new intercooler, everything cleaned etc by a relative who works at audi but obviously this was done out of hours....
    Haven't had it apart yet this time but what could it be? My mechanic suggested it could be the EGR shutting off or possibly overboosting causing too much stress on the turbo.
    I remeber that when we replaced the first engine we had to reuse the original EGR valve as the new one was faulty which makes me think it may be related.
    Can anyone help as changing turbos is very expensive as I am sure some of you may know.
    sigh....
    Dec 2011
    england
    I am on my 4th turbo and 3rd engine and also bkd. Long story but cause of turbo failures was the turbo was getting oil but oil return was not working. Shame it took VW soooo long to find it...especially as one call to my usual garage got the right answer without even seeing the car...which I suggested to VW after the 1st turbo went..shame they ignored me until they checked it after 3rd one blew.
  3. Re: BKD 3rd turbo failure, HELP!!!
    May 2010
    Devon England
    if it was me id check the oil return, and oil feed pipes, if all seems well, i would check the oil return flow rate as if the feed is slow it will cause massive problems
    VCDS HEX+CAN CODE READING AND RECODES
    OWN A MK5 GOLF TDI JOIN THE GROUP https://www.vwaudiforum.co.uk/forum/group.php?groupid=23
    2004 mk5, Viezu 140bhp Re-map, GTI front bumper, side skirts, GTI 18in rep wheels, Jamex coilovers, R32 speedo cluster, MFSW, White Roose Motorsport coolant hose's, GTTDI interior, centre consol armrest and ipod dock, leather handbrake lever
  4. Re: BKD 3rd turbo failure, HELP!!!
    Dec 2009
    london
    to be honest the turbo shattering isn't going to be caused by bad oil feed/drain as they will just seize the turbo. The were being shattered i.e into 2 pieces manifold one side and compressor seperate from the manifold.
    Anyway long story short replaced with a new euro car parts turbo and also removed the EGR flap as we have done that on other turbo cars where they were destroying the turbo in a similar fashion (shattering housings).
    so for those with turbos splitting/fracturing housings or in my case totally annihalation (sp) remove and blank off your EGR. Been over a year and a bit now.
    Dec 2011
    england
    Glad you got it sorted!
  1. Stop / Start - Here's a question for you all??????
    By RickT in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-02-2011, 10:32 PM
  2. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  3. Question P17964 = Faulty Turbo?
    By jgoodman00 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2010, 10:08 AM
  4. Question Passat B6 Turbo Failure
    By rallyfreaks in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-11-2009, 01:49 PM
  5. A3 turbo and oil pump failure
    By weiss in forum Chat - Anything with wheels
    Last Post: 28-09-2009, 08:14 AM
