Thread: Where can I get a spring clip for the radiator bottom hose ?
Results 1 to 10 of 11
  1. Where can I get a spring clip for the radiator bottom hose ?
    Worcester
    Just had to get the radiator out of my 1999 Passat Estate 1.9 TDi and found that the spring clip that secures the bottom hose (same as on the top hose) had rotted away.
    Tried the main dealer and found that you can only get the spring clip if you buy a new hose.
    Any thoughts where I can get a replacement clip since both hoses are fine?
    Cheers for your help.
    a jubilee clip of the correct size will work fine, and you should be able to get one almost anywhere.
    regards,
    448
    May 2007
    knee deep in clunge
    14 Post(s)
    Dont think you can use a jubilee clip as the clip that is missing is the u clip that locates into the plastic section of the pipe
    Northampton
    i may have a spare one from a bust rad i ripped out of a passat, where are you located?
    Worcester
    Sorry to say that a jubilee clip will not work as both the radiator and hose pipe are plastic.
    The actual spring clip holds the 2 pipes together through some grooves in the side walls. A good idea, especially if you could buy replacement clips.
    Worcester
    Thanks Turkster that would be brill.
    I'll send you some contact details.
    Catch you later.
    Yep, sorry guys, thought you meant one of those spring clamp type clips!
  8. Thumbs up
    Co Durham
    Your Dealer has been trying it on with you. I bought one a couple of weeks ago, along with the plastic clip which holds the sensor in the bottom hose.
    It's either Part No. 032121142 (37 pence) or Part No. 1J0121142 (61 pence).
    I'm not sure which one is which because I got the numbers off the receipt and they are just described as springs.
    Hope this helps.
    Apr 2007
    Chester
    Just checked ETKA the code is Part No. 032121142 thats for the retaining clip. Typical ********!!!!
    Worcester
    Cheers for that.
    I'll give them the part number and see what they say.
  1. A3 Front Spring Noise
    By sri130 in forum Archive posts
    Last Post: 07-05-2007, 10:49 PM
  2. Dip clip/ test clip eprom 8 legs
    By martyb123 in forum Archive posts
    Last Post: 21-04-2007, 11:28 AM
  3. Stone cold bottom rad hose...
    By colifeashots in forum Passat - Archive Topics
    Last Post: 24-02-2007, 04:16 PM
  4. Bottom end grunt - 1.8T
    By richjthorpe in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-02-2007, 01:09 PM
  5. r8 clip
    By barney2 in forum Chat - Completely Off Topic
    Last Post: 21-11-2006, 04:24 PM
