Thread: Steering torque sensor
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
  1. Steering torque sensor
    May 2010
    Devon England
    hi all, thismorning i fitted my new coilovers to my golf any way that went fine, when i started her up i had the amber/tellow steering wheel on the dash (power steering was fine) so i have had in the past this light on and after a drive down the road it goes out, anyway on my way home the light went RED and i lost power steering, anyway i plugged it in at a garage on my way home using LAUNCH and it had a code of steering torque sensor, i deleted the code but my steering light is now RED all the time and i have no power steering, can someone please help?????
  2. Re: Steering torque sensor
    Canada
    Hi Phil,
    Just looking at the scan we did and I found this
    http://wiki.ross-tech.com/wiki/index.php/00573
    Fault scan as below.
    Code:
    Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
       Part No: 1K2 909 144 F
       Component: EPS_ZFLS Kl.2       1301
       Shop #: WSC 00000 000 00000
       VCID: 2F43DD77C76F
    2 Faults Found:
    00573 - Steering Torque Sensor (G269)
                008 - Implausible Signal
    PS did you change anything to do with the steering wheel? My coding is 44 and yours is 22...might be it?
  3. Re: Steering torque sensor
    May 2010
    Devon England
    right i have since used VCDS to plug my car in Big thanks to Rob, your a star, and way i can not erase this code without it coming back, ive checked that i have power out of the 80 amp fuse by the battray and the fuse in the dash is fine, ive googled it and found that this fault could mean a new rack here is what VCDS has to say
    Saturday,13,November,2010,19:01:16:34667
    VCDS Version: Release 10.6.1 (x64)
    Data version: 20100831
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 7D
    VIN: WVWZZZ1KZ4W****** Mileage: 200410km/124529miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 B HW: 028 101 147 8
    Component: R4 1,9L EDC G000SG 5645
    Revision: 12345678 Serial number: VWZ7Z0D9633781
    Coding: 0000071
    Shop #: WSC 00000 028 00001
    VCID: 2265244384BD
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0021121
    Shop #: WSC 01279 785 00200
    VCID: 3A55FC230C2D
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 CC
    Component: Climatic PQ35 080 0201
    VCID: 67F375572F1F
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
    Component: Bordnetz-SG 1.0 H30 0704
    Revision: 00030000 Serial number: 00000000621926
    Coding: E48B8F0600041800001400001400000000
    VCID: 3FA38D37170F
    Part No: 1K2 955 119 B
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    Part No: 1K0 955 559 M
    Component: RegenLichtSens 005 0605
    Coding: 00217125
    Shop #: WSC 00000
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
    Component: 02 AIRBAG VW8 022 0600
    Revision: 05022000 Serial number: 0033JD0B6JZN
    Coding: 0012338
    Shop #: WSC 01268 785 00200
    VCID: 2D7FC77FCD63
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000022
    VCID: 3041DE0BDA51
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 950 LX
    Component: KOMBIINSTRUMENT VDD 3556
    Coding: 0005401
    Shop #: WSC 00390 067 57207
    VCID: 8937D3EF994B
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 C HW: 1K0 907 951
    Component: Gateway H08 0080
    Revision: 08 Serial number: 260010431806DB
    Coding: 3D0F0B48070003
    VCID: 27733557EF9F
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO 3556
    Shop #: WSC 06402 145 00197
    VCID: 8937D3EF994B
    Address 37: Navigation Labels: 1T0-919-887.lbl
    Part No: 1T0 919 887 B
    Component: Navigation 0311
    Coding: 0000002
    Shop #: WSC 01324 785 00200
    VCID: 41A78BCF61FB
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0116
    Coding: 0000052
    VCID: 3041DE0BDA51
    VCID: 2F43DD77C76F
    2 Faults Found:
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 T
    Component: 0W KSG 0560
    Coding: 81E802087F2D8505485BC61000
    Shop #: WSC 00046 412 819200
    VCID: 41A78BCF61FB
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Part No: 1K0 951 177
    Component: Innenraumueberw.004 0101
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Coding: 0000052
    VCID: 3147DB0FD15B
    Address 56: Radio Labels: 1T0-035-095.lbl
    Part No: 1T0 035 095
    Component: Radio 0311
    Coding: 0001402
    VCID: EBFB8967B3F7
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    VCID: 2C79CA7BF679
    i hope someone can shed some light on it as i dont really wanna change the rack
  4. Re: Steering torque sensor
    May 2010
    Devon England
    Quote Originally Posted by onzarob View Post
    Hi Phil,
    Code:
       VCID: 2F43DD77C76F
    2 Faults Found:
    i didnt do anything to the steering wheel, all i done was remove the TRE's since i got home ive checked all the fuses and re scaned it (i posted up my read as you posted) ive googled it and ive seen people having new racks because of this fault, i just cant believe its not something simple, i will check the code, thanks Rob
  5. Re: Steering torque sensor
    Canada
    Try this first
    Code:
    Checking Steering Torque Sensor (G269)
     Prerequisites:
    • Ignition ON
    • Engine ON (Idle)
    • System voltage at least 11.0 V.
    [Select] [01 - Engine] [Meas. Blocks - 08] Group 001 [Go!] Field 2: Steering Torque Sensor (G269) Turn the Steering Wheel multiple times completely to the left and right. The Torque Values should change. If the Torque Values do change, it's most likely an intermittent Fault in the Wiring/Connectors. If the Torque Values do NOT change, the Sensor itself or the Power Supply (Terminal 15) might be faulty. Group 004 [Go!] Field 2: Power Supply (Terminal 15), Specification: "Term. 15 ON" [Done, Go Back] [Close Controller, Go Back - 06]
    may shed some light
    PS i change you chassis code on the scan for security
  6. Re: Steering torque sensor
    May 2010
    Devon England
    Try this first
    Code:
     Prerequisites:
    • Ignition ON
    • Engine ON (Idle)
    may shed some light
    Thanks Rob, ive just tried that and the torque valves DONT change they stay at -125nm, batt voltage was 13.9, ive got a feeling i may have to change the rack
  7. Re: Steering torque sensor
    Canada
    Oh well, I suggest you leave it alone tonight and have a check of the wiring in the morning.
    PS I know were i may be able to source a second hand rack (If Required)
  8. Re: Steering torque sensor
    May 2010
    Devon England
    i was thinking the same, its to wet to lay under the car now, i hope its something silly but im not holding my breath lol
    Rob you have been a star and i cant say thank you enough for all your help today, i will will keep you updated and if the worst happens i will be in need of a rack thank you mate
  9. Re: Steering torque sensor
    Canada
    Quote Originally Posted by phil miller View Post
    No Problem....Glad to help
  10. Re: Steering torque sensor
    Canada
    Hi Phil after the telephone call and a little reading I think you need to recalibrate the rack (g85)
    Read this
    http://wiki.ross-tech.com/wiki/index...teering_Assist
    Rob
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Bentley announces detailed specification of new mulsanne
  3. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  4. New bentley continental supersports convertible
  5. Question power steering sensor? whats it do?
    By randombadger in forum Polo - Derby - Lupo - Fox
    Last Post: 15-10-2009, 07:54 PM
