Thread: Rear window problem on 2003 cabriolet
Results 1 to 10 of 10
Hybrid View
  1. Question Rear window problem on 2003 cabriolet
    May 2007
    I have a 2003 A4 cab and the rear drivers side window has stopped going all the way down, it now stops about 1/3 of the way up. Has anyone else had this prob or know what might cause it?
    Cheers.
    Apr 2007
    Hampshire
    Do you have a groaning noise coming from the motor if you hold the switch down? If so there's probably something blocking the window in the slider track, means taking the side panel off the car to check but worth while if you've just got some muck or a twig jamming things.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
    May 2007
    I haven't heard a groaning noise coming from it, it seems to stop in exactly the same place every time as if it's meant to stop there but I'm sure it went all the way down when I bought it.
    I don't fancy taking the side panel off myself as it will all end in tears! I expect that will cost a bit at a dealer too.
    Apr 2007
    Hampshire
    The panels gotta come off else you'll never know. If your not happy doing it yourself then only option is the dealer, and that'll set you back a 3 figure sum for them to just look into what the problem is, and then another 3 figure sum to fix what they find!
    May 2007
    That's what I was afraid of!
  6. cabriolet rear window
    Jul 2007
    i have just had mine replaced under warranty free of charge by audi theres a big problem with these. Mine has done the same as yours if the cars under 60k with a good audi history there sort it.And mine had never been serviced at the dealer that done the work and while it was there they replaced the water pump cambelt thermostat rear beam bush,s front struts £2300 pounds worth all free of charge now thats good service the car was over three years old and covered 52,000 miles
  7. Re: Rear window problem on 2003 cabriolet
    Jul 2007
    i took mine to my local audi main dealer and had it fixed totaly free off charge as good will car was five years old but under 60,000 miles take it there they no theres a problem
  8. Re: Rear window problem on 2003 cabriolet
    Sep 2007
    Quote Originally Posted by danc View Post
    hi,
    I Have A 2003 A4 Cab And The Rear Drivers Side Window Has Stopped Going All The Way Down, It Now Stops About 1/3 Of The Way Up. Has Anyone Else Had This Prob Or Know What Might Cause It?
    Cheers.
    Hi Your Cable Will Have Jumped On The Window Drive And Will Need Reruning . Trim Off And Window Out About 2.5 Hours Did Mine My Self Ok Now
  1. Cabriolet Rear Window
    By Timja in forum 80 - 90
    Last Post: 25-03-2010, 11:44 PM
  2. Audi Cabriolet 1994 Power Window Problems
    By atlanta8967 in forum 80 - 90
    Last Post: 05-08-2008, 09:53 AM
  3. Replies: 2
    Last Post: 10-07-2007, 10:16 AM
  4. Electric window puzzle - 1994 cabriolet
    By ping_zero in forum 80 - 90
    Last Post: 27-11-2006, 12:04 AM
  5. Broken rear window
    By oceanwizard in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-11-2006, 05:10 PM
