Thread: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Aug 2010
    harlow uk
    i recently bought a second hand ecu for my 1999 vw passat 1.8 t 20v and have been told i need the skc to programme it to my immobiliser etc the key light just flashes does anyone know how to obtain it or anyone that can fix it for me asap please help im stuck with my precious car of the road its undriveable
  2. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Quote Originally Posted by greenfumb View Post
    Do a search on Ebay, leads and software are available to obtain the SKC (about £20 with delivery).
  3. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Aug 2010
    harlow uk
    my pal had one of the kits tryed it earlier but did not accsess the code
  4. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Apr 2009
    With the right equipment, you can lift it from the
    instrument cluster-immobilizer. But you might
    need VAG-COM to get it to go back in again.
    Try a vag specialist or tuning shop, near you,
    for a call-out service.
    Regards
    Jim
  5. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Aug 2010
    harlow uk
    thanks jim
    but i have the coding from my ecu (which is broken) and cluster etc i just dont have the code from the new ecu i have heard something about vagtacho but vagcom does not work my mechanic tryed it on his i'd do pretty much anything if someone could get the code from my second hand ecu lol
  6. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Jun 2006
    UK, Mids
    You can get the code with VAGCommander software and cable (not the same as vag-com/VCDS) and I think you can with VAG-Tacho software too. "reading security access code of immobilizer"
    You can get it from ebay.....
    http://cgi.ebay.co.uk/VAG-K-CAN-5-1-...ht_6114wt_1008
    Audi A8 - 2015 - 3.0TDI
  7. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Norfolk
    I'm confused. If you haven't changed the cluster, why would you need an skc. The immobiliser is in the cluster so your keys are still coded to that cluster. The engine ecu just needs the same coding that the original engine ecu had. You can do that with VCDS. It's only got a few settings like transmission, country etc.
  8. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Aug 2010
    harlow uk
    Thanks Snapdragon will go and have a look now Thanks
    Thanks Martin1810 thats what i thought but when i pluged in the new ecu the key light flashed and my mechanic tryed the coding he said i need a pin from the new ecu i have got my ecu coding number, service code, pin number from my oe ecu but need these numbers from the new one im a bit confused i know a bit about cars but this baffles me lol
  9. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Did you select the correct immo?
  10. Re: vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    Norfolk
    When you try to start the car, what happens and what fault code do you get. Are you sure it is not the cluster that is faulty. Did you save the coding from the old engine ecu before you removed it. If not, it should be possible to work it out as long as you have the engine code. I can't see why you need numbers from the new engine ecu as it will still be set for the previous car.
  1. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  2. Help please with problem on my A6 (flashing Glowplug light)
    By oDUTCHYo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-08-2010, 10:45 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  5. How does the Quattro system work?
