Thread: Condensation problem..
Results 1 to 10 of 11
  1. Condensation problem..
    Aug 2007
    Went out to the car this morning to find heavy condensation inside the windscreen, not really what I would expect for a 4 year old car. Heavy dew and about 5 deg outside.
    The carpets seem dry so I can't see where it could be getting wet. It needed wiping down before the aircon could take care of the rest. A/C seemed fine but I was wondering if anyone knows of problems with particular filters, seals or drains anywhere?
    I'll try and get it in the garage and stick a dehumidifier in it, but no good until I trace where the moisture is getting in.
    (I did previously have this problem, but much worse, on a Seat which turned out to be a leak at the firewall - Seat had to put in all new carpets and soundproofing under warranty.)
    Its an 06 140 TDi Estate with a full VW service.
  2. Re: Condensation problem..
    Apr 2010
    I would check that the pollen filter cover has been put back correctly. Also I used to have a Seat Leon, that used to leak via the door seals..
    06 Vw Passat 2.0TDI SE Wagon. Daily
    89 Vw Polo Cl Saloon. Project
    03 Seat Leon TDI. Gone.
  3. Re: Condensation problem..
    Aug 2007
    Thanks, pollen filter ok. any other thoughts?
  4. Re: Condensation problem..
    Apr 2007
    France
    12 Post(s)
    Have you felt under the carpets? If there is water getting in it will run down and go straight under them.
    1996 Laguna 2.2D
    1977 MGB roadster
  5. Re: Condensation problem..
    Jul 2010
    ireland
    my 07 passat was/is the same, found a leak, carpet soaked. Leak fixed but cant get carpet dried out, hence condensation
  6. Re: Condensation problem..
    Aug 2007
    Quote Originally Posted by pasb6 View Post
    When I had this problem with my SEAT we ended up up having the carpets and underlay stripped out by the dealer and replaced under warranty as it was a known fault which they had not addressed.
  7. Re: Condensation problem..
    Norfolk
    As your car is an estate I would look in the spare wheel well for a pond. Every time you open the tail gate in rain, a little water runs off the tail gate into the boot. Sometimes enough collects in the wheel well to cause condensation. For some reason, on the B6, this always shows up at the windscreen first.
  8. Re: Condensation problem..
    Aug 2007
    I'm going to put the car in the garage overnight and then strip out all the carpets tomorrow to see if i can find any damp. After that, I'll put a dehmidifier in to dry everything out then try and see where it reoccurs.
    I was wondering if anything gets in or if any problems are casused by the aircon system?
  9. Re: Condensation problem..
    DSG4ME Guest
    Make sure the windows are all fully done up, a slight gap will allow the weather in, mine was frosted over in the garage the other day where the weather has been so extreme lately.
  10. Re: Condensation problem..
    Aug 2007
    Yes, i find it infuriating that there isn't auto closure on the alarm/key to close all the windows without having to stand there with your finger on the key.
  1. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  2. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  3. Help! Clicking window problem.
    By dcorcouk in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-03-2008, 09:58 PM
  4. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
