Thread: Help! Diesel filter problems
  1. Help! Diesel filter problems
    Scottish Highlands
    I've just carried out a 10k service on my 2005 A4 2.0TDI. (Oil, filter, pollen filter, air filter and fuel filter)
    When removing the old fuel filter, I removed the two hoses nearest the bulkhead and then removed the metal clip which holds the black plastic 'one way valve' with the other two hoses in the top of the filter.
    When I pulled the valve out of the old filter it came apart into two pieces revealing the inside of the valve. I therefore pressed it back together and refitted the new filter hoping all would be fine.
    However, since fitting the new fuel filter, diesel is leaking out of the one way valve somewhere and leaking all over the top of the filter in the engine bay! It seems as if this valve is sticking?
    Anyone ever had this problem and if so what's the solution? New black plastic valve?
    Cheers,
    Davie.
    Oct 2010
    Here And There
    Yea, there just like most parts on modern cars. Flimsy and not of a quality build. You would be better to replace it even if you do get it to stop leaking. It will end up giving you problems with power and starting
  3. Re: Help! Diesel filter problems
    Jul 2010
    Lithuania, Panevezys
    I have the same problem, changed old filter, but it still leaks..
  4. Re: Help! Diesel filter problems
    Scottish Highlands
    Purchased a new T-piece from Audi dealership today for aound £18.
    Now fitted and seems to have sorted the problem thankfully.
    On the downside, managed to kerb one of my new wheels this morning and can't even blame the wife!
    Oct 2010
    Here And There
    Quote Originally Posted by daviemac11 View Post
    Good job about T piece, say nothing and blame her after the next time she is in. After telling the story to people so many times about HER doing it, you will convience yourself that it was her and therefore blanking the whole experiance from your mind :-)
  6. Re: Help! Diesel filter problems
    Scottish Highlands
    Ah, that sounds like a plan. Good thinking!
    Cheers.
    Oct 2010
    Here And There
    Cheers.
    Years of pratice :-)
  1. Please Help How do I change Diesel Fuel Filter on MK5 Golf
    By Crackshot in forum Golf MK5 - 2004 - 2009
    Last Post: 31-01-2011, 08:36 AM
  2. Diesel Fuel Filter Leak - doh!
    By waaarp in forum Golf MK4 - 1999 - 2004
    Last Post: 29-06-2010, 01:51 PM
  3. Replies: 0
    Last Post: 10-02-2010, 01:39 PM
  4. How To: Modify/repair leaky Passat pollen filter
    By bobbinz in forum Volkswagen
    Last Post: 20-05-2009, 01:32 PM
  5. passat diesel filter
    By alexf2828 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2009, 09:40 PM
