Thread: 1st gear difficult on POLO.
  1. 1st gear difficult on POLO.
    It has always been difficult to select 1st gear on our POLO. There`s a less experienced driver behind the wheel now and I`m wondering if anyone else has had the same problem and if there`s an easy remedy.
    Hi, there's no easy solution for you to do at home, but it could be rectified very painlessly at your local VW retailer.
    It's likely that the gear linkage needs adjusting and this is fairly simple providing you have the correct jig to hold the gear lever in position while the gear linkage is adjusted.
    There is a possibility that it's a clutch issue but i'd reccomend the cheaper option of a gear linkage adjust first.
    Hope this helps,
    448
    May 2007
    newcastle
    same as mine, how much u think that vw garage will charge?
    In my opinion it should certainly be no more than an hours labour.
    ask them to quote you a price first if possible, although they will probably want to diagnose the fault themselves rather than take your (or my) word for it!
    May 2007
    newcastle
    thanks for the info, got a number of sum one at work of his mates garage
  6. 1st Gear
    Thanks for help............will have mechanic have a look, most times its ok......othertimes feels like theres a small obstruction.......releasing the clutch and selecting 1st again generally does the trick.
  1. DSG Gear Box
    By MikeXR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-06-2007, 07:46 AM
  2. Help Please! 1st gear jumps out of gear
    By TollyTDI in forum Toledo
    Last Post: 17-06-2007, 07:50 AM
  3. 1sr gear
    By davegilsenan in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-06-2007, 03:02 PM
  4. Gear jumps out and non smooth gear changes
    By RIZWAN180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 09:45 AM
  5. Changing a bulb. Is it so difficult?
    By hallgreen in forum Audi A3 - Archive Topics
    Last Post: 01-12-2006, 07:43 PM
