Thread: golf 1.9 TDI 'limp mode'
Results 1 to 10 of 16
  1. golf 1.9 TDI 'limp mode'
    Aug 2009
    Barnsley
    I seem to be having the same problem as have a number of golf owners by the looks of things. when driving (mainly motorways or up steep hills) the turbo decides to disappear and go in to limp mode, but when the car is turned off and back on it is immediately fixed and back to normal. also it seems to be doing low mpg (around 39) during long , steady motorway drives.
    I have a Golf mk 4 1998 1.9 TDI
    I've looked in previous forums on here regarding the problem, found that the mass air flow sensor could be at fault ,but when i have checked this it already seems to have been changed in the cars life as its not the bosch which i believe is standard? would this make it quite likely that this is not at fault?
    Has any body got any other ideas?
  2. Re: golf 1.9 TDI 'limp mode'
    2019 Post(s)
    What is the engine code or horsepower? You need to have a fault code read done, guessing can waste money. If you get code 17958, that is normally turbo vane carbon fouling but can also be an N75 issue, a vacuum leak or in rare cases it can be the Air mass Meter and in even rarer cases, the MAP (boost pressure) sensor.
  3. Re: golf 1.9 TDI 'limp mode'
    Aug 2009
    Barnsley
    Cheers,
    Its the 90 BHP.
    How much does it cost roughly to get the fault code read?
    cheers
  4. Re: golf 1.9 TDI 'limp mode'
    Southern County Softy
    20 Post(s)
    Look in the vagcom section for a member in your area.
    Should be able to get a scan for a few beer tokens...
    A4 2.5 tdi QS (mapped)
  5. Re: golf 1.9 TDI 'limp mode'
    2019 Post(s)
    90PS changes things a lot, which engine code?
  6. Re: golf 1.9 TDI 'limp mode'
    Aug 2009
    Barnsley
    sorry for the delay in the reply (iv been off line for a while) im still having the problem!!!
    Where do i find the engine code?
    thanks
  7. Re: golf 1.9 TDI 'limp mode'
    Southampton, UK.
    The engine code can be found on a sticker on the cambelt cover - 3 letters, eg. AGR.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  8. Re: golf 1.9 TDI 'limp mode'
    ahh i have had the same problem i have the same engine. n75 valve its under £40 from vw either leeds road or bradford road will get you one. 2 mins to fit a monkey could do it and wella it is sorted
  9. Re: golf 1.9 TDI 'limp mode'
    Aug 2009
    Barnsley
    the engine codes AGR.
    how can i tell if it is likely to be the N75 valve, dont want to start guessing if there is a chance it could be somthing else.
    cheers
  10. Re: golf 1.9 TDI 'limp mode'
    Aug 2009
    Barnsley
    Rite any way iv had a fault code read done this eveining and if has come up with the following code:
    00575 - Intake Manifold Pressure
    17-10 - Control Difference - Intermittent
    Readiness: N/A
    any one got an idea what work needs to be done?
    Dave
  1. Nightmare time with my '01 Golf 1.9 TDi! Please help!
    By DanielVale in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2008, 11:53 AM
  2. Can I use a Golf 1.9 tdi gearbox on a 1.4 tdi lupo?
    By pietch in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2008, 04:39 PM
  3. 1.9 TDi help.....
    By Estoril Ben in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2007, 10:52 AM
  4. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  5. 1999 Golf 1.9 TDi Power Steering Fluid Low
    By gazza57 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 12:36 PM
