Thread: white smoke and smell of unburnt diesel
Results 1 to 10 of 12
  1. white smoke and smell of unburnt diesel
    May 2008
    help i have white smoke and the acid smell of un burnt diesel coming from the exhaust or my 130 awx just changed the injector loom and it had no change car has done 114k faultless untill now pls help!!!!
  2. Re: white smoke and smell of unburnt diesel
    May 2008
    had it hooked up to vag com no faults were found
  3. Re: white smoke and smell of unburnt diesel
    Norfolk
    Sounds like the glow plugs are not working. Is it worse on cold start up. Check the glow plugs for power.
  4. Re: white smoke and smell of unburnt diesel
    May 2008
    no glow plugs are a ok just new it will do it when hot starts fine when cold
  5. Re: white smoke and smell of unburnt diesel
    Norfolk
    How does the engine sound. Unburnt diesel when warm would normally mean injection timing is out. This doesn't happen on PD engines unless the cam belt slips or the cams are worn. Another possibility is injector seal failure.
  6. Re: white smoke and smell of unburnt diesel
    May 2008
    i think its an injector just changed the loom and the camshaft looks like new i have always used the correct 505.01 oil and change it every 6/8k
    think im gona go with it being an injector
  7. Re: white smoke and smell of unburnt diesel
    Norfolk
    See if you can get a VCDS engine measuring blocks scan. The injector figures might give you a clue.
  8. Re: white smoke and smell of unburnt diesel
    May 2008
    iv got that but dont know what im lookin for is it block 13
  9. Re: white smoke and smell of unburnt diesel
    Norfolk
    Blocks 1, 4, 8 and 13 should have injection data. Depends on what VCDS you use and what engine it is. This info is all available in the pro version of VCDS.
  10. Re: white smoke and smell of unburnt diesel
    May 2008
    had the injectors looked at today told me they ar ok and firing the correct amount of fuel think il have to bark up another tree
    could this be the start or a head gasket a fair bit of back pressure is there when the oil cap is removed
  1. White smoke on cold starting
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2013, 10:57 AM
  2. HELP!! White Smoke from Exhaust!!
    By GJC in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-06-2010, 11:54 AM
  3. Question Excessive smoke when cold, Touran 1.9 diesel
    By tjwatts in forum Touran - Sharan - Caravelle
    Last Post: 20-04-2010, 08:56 AM
  4. white smoke, burning smell
    By rambodinio in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 31-10-2009, 05:36 PM
  5. White Smoke, burning smell, low mpg...
    By friedgold in forum Archive posts
    Last Post: 30-12-2007, 10:33 PM
