Thread: Climate Control Calibration
  1. Climate Control Calibration
    Ardfern
    8 Post(s)
    Hi, I have a 2003 1.9 tdi SE Avant. I removed the C/C unit to replace it with another which however as not quite the correct model, so I refitted the original. Now, I suspect that it is not working quite as it should, as the air temp is different on each side even when set to the same temp!
    I have VCDS and wonder if someone could lead me through the process of calibration.
    Thanks.
  2. Re: Climate Control Calibration
    Sep 2009
    Apollo
    Post the complete Auto-Scan from this car using our current release and I'll take a look at it.
  3. Re: Climate Control Calibration
    Ardfern
    8 Post(s)
    Hi, Thanks for your response. I shall do a scan at the week-end and try to post it.
    Best wishes,
    Niall
  4. Re: Climate Control Calibration
    Ardfern
    8 Post(s)
    Hi, At last I have found a moment to do a scan which I have attached.
    I would appreciate any advice you can give from a reading of this log.
    Many thanks.
  5. Re: Climate Control Calibration
    Sep 2009
    Apollo
    Based on the scan data:
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1219
    Coding: 00000
    Shop #: WSC 63251
    VCID: 60C4AC41CA3F
    No fault code found.
    It looks like Basic Settings Group 001 will run the Potentiometer & Flap Alignment. I'll also note some HVAC modules will support Group 000 as well. If the later isn't supported, it will result in an Error, Not Available message and that will not cause damage or harm, it simply won't do anything.
    I would personally try both one at a time and check for any fault codes after each one. If the temp. Potentiometer/flap motor does not run the test properly you should have a fault code stored.
    Also look at the Measuring Blocks for the Left and Right Temperature Flap Motors to see if they look reasonable. It might not hurt to check them before and after the mentioned Basic Settings to see if anything's changed.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Please Help A4 2001 Climate Control Unit
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2009, 05:11 PM
  3. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
