Thread: Horn problem
Results 1 to 10 of 10
  1. Horn problem
    Runcorn,Cheshire
    I have checked the fuse and thats ok,when i had the fuse cover off and pressed the horn i can hear a click noise like its making contact but no sound ...any ideas peeps
    Dave
    Apr 2007
    Hampshire
    Something electrical, unless you've got nesting sparrows in the horn muffling it! Suggest you check power at the horn & check for corroded connections.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  3. Re: Horn problem
    May 2008
    Quote Originally Posted by davec573 View Post
    Dave
    have you found the problem yet?
    i have the same issue
  4. Re: Horn problem
    essex
    just to the right of the left hand foglight as viewed from drivers seat facing forward, there is a multiplug that has the horn(s) connected to it and also the foglights, i think are attached to the same multiplug.
  5. Re: Horn problem
    kent
    1 of my horns has packed up,
    where abouts are they located??
    and are they together, or 1 each side of the car??
    Stu
  6. Re: Horn problem
    essex
    there are two, well there is on mine anyway. there is one on each side of the car very close to back of front spotlights.
  7. Re: Horn problem
    kent
    cool, do i need to remove headlights/bumper etc???
    or is there a quick way to get to them??
    Cheers.........Stu
  8. Re: Horn problem
    essex
    take off the undershield underneath the engine and you wil be able to get to them
  9. Re: Horn problem
    kent
    cheers for that, i'l find out which one then av a look
    Stu
  10. Re: Horn problem
    kent
    what a pain in the ar$e to get back on again GRRR!!!
    and i didn't even need to!!
    the horns on mine are placed under each headlight, so 4 screws later i'd found it!!
    unplugged it, went to put on the replacement only to find the Halford's jobby wouldn't fit
    thoroughly pi$$ed off, decided to put it all back together and put up with a pathetic labrador puppy style hooter and hey presto, they both work again!!!!!!!!!!
    I think my car is possessed ???????????? things keep going wrong, but they seem to fix themselves
    Stu
  1. Missing Horn
    By Alan Griggs in forum Chat - Anything with wheels
    Last Post: 20-02-2008, 02:27 PM
  2. alarm battery/horn
    By paddymm in forum Audi A4 - Archive Topics
    Last Post: 04-04-2007, 09:57 PM
  3. S3 Horn sounds like Noddys Car
    By Clack in forum Audi A3 - Archive Topics
    Last Post: 27-10-2006, 08:05 PM
  4. A3 horn/ steering rack
    By toshaudi in forum Archive posts
    Last Post: 26-09-2006, 02:49 PM
  5. airbag & horn problem
    By Kat2006 in forum Archive posts
    Last Post: 03-08-2006, 01:21 PM
