Thread: A6 Avant 53 plate "Vacuum Pump" recurring fault
  1. A6 Avant 53 plate "Vacuum Pump" recurring fault
    May 2010
    Lytham UK
    Hi all
    I have a recurring Vacuum pump fault, however the garage have checked out the pump and it appears to function OK as does the associated non-return valve.
    Due to the lack of Haynes, or similar, manual for this model I find it difficult to work on the car myself, I am also unwilling to pay my local dealership to keep their mechanics in gold-plated tools and Gucci overalls (£150 to change the oil in my gearbox of which only £50 was for the actual oil!).
    I do not have the equipment to read the codes myself, but I believe that it is the same as the "17887/ p1479/005241 - brake boost vacuum system: Mechanical failure" that comes up.
    Associated with this, I think, is the fact that the vacuum is not being held by the servo (i.e. the brake pedal is hard first thing in the morning before starting the engine, previous cars I have had retained some vacuum in the servo system overnight so there is a soft pedal even before starting the engine).
    Is there a common fault that would cause this? Otherwise I'm guessing that the vacuum hoses, the sensor which raises the fault with the ECU or the servo is at fault.
    I am in the Lytham St Annes / Fylde Coast area of Lancashire, UK. Can anyone recommend a good independent specialist in my area.
    Thanks for reading, I would appreciate any thoughts you may have.
    As a supplementary question, my A6 is a 2.4 Petrol with Multitronic box (it does not appear immune to the multitronic problems and jerks once in a while, in reverse only).
    My question is simply this, what sort of real world fuel consumption should I be seeing and how accurate is the readout on the dash, should I be brimming the tank and clocking the miles the old fashioned way?
    I currently get around 27 on my 14 mile a day commute but less than 33 on the motorway.
    Grim
  2. Re: A6 Avant 53 plate "Vacuum Pump" recurring fault
    Sounds to me like you may have a split hose between the servo and the pump. Check these carefully.
    Can't help with a recommendation in that area I'm affraid.
    I have the same engine as you and a multi. I get about 17 MPG around town with a heavy foot. Motorway I get around the 35 mark if I keep to the NSL (who doesn't ). I used to commute about 30 miles mixed road and could get it as high as 36 with careful driving.
    Thats a littl ehigher than you are seeing. Could be down to driving styles. Whats the service history like on yours? Might just need some new plugs and filters.
  3. Re: A6 Avant 53 plate "Vacuum Pump" recurring fault
    Please provide the engine code from the ID label in the spare wheel bay. Is you plenum chamber retaining water ( down the side of the battery.) Regards Peter
  4. Re: A6 Avant 53 plate "Vacuum Pump" recurring fault
    The message "brake boost vacuum system: Mechanical failure" refers to a mechanical pump as per the deisel, you have an electrical pump with a vacuum sensor and the electric pump is controlled by a relay which also may be a cuse of your problem. Do you actually run out of vacuum for the brakes with your foot off the throttle. Regards Peter
  5. Re: A6 Avant 53 plate "Vacuum Pump" recurring fault
    May 2010
    Lytham UK
    Thanks for the prompt replies, to answer the questions both have asked:
    Although the service history is a little patchy, the last service (about 4,000 miles ago) was carried out, at great expense, by the local Audi dealer (Preston Audi) the fault light has become apparent since then. I don't know about the servo not retaining vacuum, I didn't notice until it was suggested I check!
    Engine code is BDV and transmission is FRY
    I haven't checked the plenum chamber yet, will look later.
    I have not yet run out of vacuum at any point whilst driving.
    The fault code according to my garage definitely mentions "Mechanical Failure" which is why I suggested it was similar to the "17887/ p1479/005241 - brake boost vacuum system: Mechanical failure" unfortunately searching the forum I have not been able to find a post that matches my problem more closely.
    Grim
  6. Re: A6 Avant 53 plate "Vacuum Pump" recurring fault
    I suspect this is a vacuum sensor fault. Remove the black plenum cover and you will see the sensor on the pipe. Regards Peter
  1. Audi Q7 VCDS errors
    By creatorul in forum VCDS - Help Requests
    Last Post: 22-01-2016, 10:11 PM
  2. Please Help Fitted dis and cruise but having problems with coding etc
    By ukdan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 06:45 PM
  3. Help needed from experinced A6 owners
    By robmorphet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-03-2010, 08:27 AM
  4. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
  5. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
