Thread: A4 2.0 T FSI 220 2006 Temp Gauge moving down
Results 1 to 10 of 10
  1. A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Dec 2006
    For the first time ever the temp gauge on my car has started to fluctuate slightly... it always used to steadily warm up to the exact middle (upright) position and stay there. Today as I drove it dipped back down a tad... then back up... then back down... it never went over the mid line... just under.
    Should I be worried?
  2. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Sep 2008
    chester
    17 Post(s)
    Looks like the coolant temp sender.ok to drive till you get it sorted.
  3. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Dec 2006
    If this is duff will it show up on a vag com scan?
  4. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Sep 2008
    chester
    17 Post(s)
    No not always,temp gauge fluctuations are usually caused by the sender or stat,as you say the temp is building up slowly and to 90 as normal before dipping down I would say its the sender,its cheapest to fix anyway so its advisable to change it first.
  5. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    redcar
    have noticed the same on mine A4 2.0t fsi avant 2005, will be looking to get the temp sender changed.
  6. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Dec 2006
    Morning!
    I actually called the Audi garage yesterday to make a booking to get this looked into. They said it's normal for the temp to drop a little below 90 on the gauge and then go back up again.
    Basically my gauge stays on 90 most of the time... but occasionally drops a bit lower... then goes back up again...the service advisor said this was OK and to be expected at this chilly time of year...
    This is the sixth VAG car I have owned and all the previous ones stayed at 90 constantly after the engine warmed up...
    Mmmmmmm
  7. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    May 2008
    Doesnt sound right to me, All my VAG cars (10+) have stayed at 90 and never move from 90 once they are warmed up, even in the harshest winter.
    How far from 90 does yours drop? Back towards 70? Or just a mm down from 90?
  8. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Dec 2006
    Just a mm or two down... never down any further...
    How much is a temp sensor to buy?
  9. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Dec 2007
    last 1 i got was Ł22+
    very easy change bit fiddly tho get some G12
  10. Re: A4 2.0 T FSI 220 2006 Temp Gauge moving down
    Sep 2008
    chester
    17 Post(s)
    Same here,90 degrees,invest in a genuine sender,last one I bought Ł28 with the o ring.
  1. A4 B6 2.0 fsi Engine ecu softcode ???
    By matta4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2010, 01:44 PM
  2. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  3. Audi A4 temp gauge
    By TomPetrilli in forum Audi A4 - Archive Topics
    Last Post: 18-01-2007, 11:35 AM
  4. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
