Thread: What is the correct amount of Engine Oil required?
  1. What is the correct amount of Engine Oil required?
    Oct 2010
    Ireland
    Dear Experts, What is the correct amount/volume of engine oil required for a 2005 audi a4 2.0 TDI (140BHP) engine? I don't have a user manual to know the exact specification. Many thanks, Paddy.
  2. Re: What is the correct amount of Engine Oil required?
    Mar 2009
    London
    Well if it's a 2 litre engine, it'd be 2 litres
    Just top it up and use the dipstick to see when it's reached between the min and max levels.
    04 A4 1.8
    T S-Line Multitronic (190bhp)
    Misano Red - Factory RS6 18" Alloys - Rear Folding Seats - Park Distance Control - Private Number Plate
  3. Re: What is the correct amount of Engine Oil required?
    Oct 2010
    Ireland
    Hi, Someone said to me this morning its 3.8 litres of oil. I have around 4.5 litres in, so I need to leave some out.
  4. Re: What is the correct amount of Engine Oil required?
    Sep 2008
    chester
    17 Post(s)
    3.8 is correct you certainly do need to leave some out, put about three lts in then add the rest slowly till it comes on the dip stick,start the engine to fill up the oil filter housing,then switch off,allow to settle for half n hour then re dip it and add oil a bit as a time to get it between the low n high,its too expensive to waste!,also over filling is not recommended,so just take your time. PS what oil are you putting in?
  5. Re: What is the correct amount of Engine Oil required?
    Oct 2010
    Ireland
    Hi Nevo, I think I used 5w30 fully synthetic (it definately had a 5w part to it.) It was what they gave me at the auto-store. I'll get back to you later this evening when I get home to check the type and manufacture of oil.
  6. Re: What is the correct amount of Engine Oil required?
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Quote Originally Posted by paddyjoesoap View Post
    Make sure it meets VW507 eh?
    D.
  7. Re: What is the correct amount of Engine Oil required?
    Oct 2010
    Ireland
    Hi all,
    the engine oil i used was 5w40 Valvoline synthetic blend. I mistakenly said 5W30 in a previous post.
    it says on the back:
    " DuraBlend Diesel SAE 5W-40, API: CF, ACEA:B3/B4, Ford M2C-917A, MB-Approval, Approved under VW standard 505.00/505.01"
  1. Please Help Buying a used A4, any advice please
    By rubix in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-06-2010, 05:02 PM
  2. Identify oil leak after oil change
    By turbocharlie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-09-2009, 01:56 AM
  3. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  4. Answers from an oil expert...
    By oilman in forum Archive posts
    Last Post: 20-01-2008, 05:30 PM
  5. '92 MKII no oil pressure (0)!
    By 2old2turbo in forum Jetta MK2 - 1984 - 1992
    Last Post: 12-10-2007, 02:30 AM
