Thread: Plenum Chamber Drain Holes
Results 1 to 9 of 9
Hybrid View
  1. Plenum Chamber Drain Holes
    Oct 2010
    manchester, uk
    I have owned my 97 A4 for over 11 years and I frequently have to unblock the drain holes under the battery and the servo, to drain water that has collected.
    Since this usually involves removing the battery, this can be a pain.
    Reading through the postings I can see that this a common problem and was wondering if Audi, or anyone had come up with a solution?
  2. Re: Plenum Chamber Drain Holes
    Apr 2009
    Quote Originally Posted by manclad View Post
    Yeah, remove the rubber bungs and throw them in the nearest bin,
    VAG have now started doing this too.
    Regards
    Jim
    3 0 0
  3. Re: Plenum Chamber Drain Holes
    Oct 2010
    manchester, uk
    Quote Originally Posted by yaman View Post
    Regards
    Jim
    Are there any problems regarding the removal of the bungs?
    I was thinking along the lines of fumes being dragged in and such.
  4. Re: Plenum Chamber Drain Holes
    Sep 2009
    ramsgate
    Stick a peice of stiff wire down them and hook them somewhere accesible so you can do them everytime you fill up with washer say...
  5. Re: Plenum Chamber Drain Holes
    Oct 2010
    manchester, uk
    Quote Originally Posted by portovechios View Post
    I actually tried this a couple of years back, but whilst it did allow some water to drain it didn't get rid of the crap and they soon blocked again.
  6. Re: Plenum Chamber Drain Holes
    Apr 2009
    Are there any problems regarding the removal of the bungs? I was thinking along the lines of fumes being dragged in and such
    The bungs were never designed to be airtight (fume-tight)
    When they are airtight....... they are water-tight and flooded!!!
    This fume theory is nonsense, and frankly, doesn't hold water
    (no pun intended)
    Regards
    Jim
  7. Re: Plenum Chamber Drain Holes
    Oct 2010
    manchester, uk
    Found this https://www.vwaudiforum.co.uk/forum/s...ad.php?t=82286
    Looks like removal might lead to a fume problem
  8. Re: Plenum Chamber Drain Holes
    Apr 2009
    I suspect his fumes were entering the car from another source,
    probably the boot. Where were they coming from, the exhaust?
    If the fumes were coming from the front of the car, then something
    needed fixed. To concentrate on drain-holes is bizarre.
    Think about it, how could the reinstatement of an non-airtight
    bung stop anything?
    Regards
    Jim
  9. Re: Plenum Chamber Drain Holes
    Oct 2010
    manchester, uk
    bung stop anything?
    Regards
    Jim
    I agree.
    I will remove them next chance I get and report.
  1. At last! A uk recall for the passat brake failure water leaks plenum chamber
    By snapdragon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2016, 11:27 AM
  2. oil fumes , plenum chamber drain valves
    By billy g in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2009, 12:49 PM
  3. plenum chamber drain valves
    Last Post: 16-10-2009, 03:06 PM
  4. Plenum chamber recall
    By Stu8 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2009, 09:30 PM
  5. Water leak and drain holes
    By Abbs985uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-03-2008, 03:16 PM
