Thread: Power loss intermittent
  1. Power loss intermittent
    Aug 2007
    Hook Hampshire
    21 Post(s)
    This problem has happened a few times but for only about 5 to 10 seconds at a time. When I am accelarating I notice that the revs increase but the cars accelaration becomes very lethargic. So the reves can reach 4000rpm and the speed struggles to get over 40mph. I ease of the accelarator and normal performance resumes. Although it can feel like a clutch slipping I am sure that this is not the case (multitronic) and am thinking its more turbo/fuel related. The fault code reads
    "0575 Intake manifold pressure 08-10 control limit surpassed"
    Any help would be appreciated.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Power loss intermittent
    Looks like the turbo might be over bossting. Could be either a knackerd wastegate or the VNT acutator might be sticking, or a more serious fault with the turbo.
    Do you have VAG-Com? There are some Measured Values you can read to determine which of these might be at fault. PM me your email if you want me to send the details.
  3. Re: Power loss intermittent
    Dec 2005
    How did you get on with this Shabaz? Ever find out what it was?
  4. Re: Power loss intermittent
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I hopefully have solved the problem as it has not recurred since. It was probably sticking vanes or the actuator, but as it only happened about 3 times over as many months, it is difficult to know exactly what could have been the cause. I used cataclean in a high dosage, so that may have cleaned the system. Using a vacuum pump, the actuator moves freely, so until it happens again, I can't do much more.
    I found a very good post which explains some theory and how to check the various parts of the system. http://briskoda.net/forums/topic/181...urbo-problems/
  5. Re: Power loss intermittent
    May 2007
    Falmouth, Cornwall
    Quote Originally Posted by shabazmo View Post
    It happens to my 1.9 tdi, always when going up this same hill when the engine/turbo is under constant load. If I stop and turn the ignition off the problem seems to clear. I have never been brave enough to dig deeper incase I find something i don't like (and my wallet has to get a lot lighter!).
    Chris
  6. Re: Power loss intermittent
    Dec 2005
    Just for reference, this was a turbo problem. I wasted £95 on an N75 valve before I found this out! A re-condition of the turbo solved it.
  1. 2002 Sharan 1.9 TDi Intermittent power loss.
    By dazmac in forum Touran - Sharan - Caravelle
    Last Post: 12-08-2014, 07:51 AM
  2. Intermittent loss of power / turbo
    By chev in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-10-2010, 11:38 PM
  3. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  4. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
  5. Allroad 2.5 Tdi - Intermittent Loss of Power
    By EddieM in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-08-2007, 03:24 PM
