Thread: Audi 2.4 Fuse 5 Blows
Results 1 to 10 of 17
  1. Audi 2.4 Fuse 5 Blows
    Oct 2010
    Plymouth
    In need of your help, where do I start fuse 5 always blows, need your advise urgently.
    Thanks,
    Wayne
  2. Exclamation Re: Audi 2.4 Fuse 5 Blows
    Apr 2009
    Hampshire
    Does the manual tell you what fuse 5 does???
    This will help you in diagnosing the fault.
    If you dont know what the fuse does check everything you can, to see what is not working in the car!
  3. Re: Audi 2.4 Fuse 5 Blows
    Oct 2010
    Plymouth
    Been fault finding and can now confirm that with the climate panel removed the fuse does not blow, I have even gone as far to now confirm that the fuse only blows when the 'D' connector is plugged into the climate panel. Now what I dont know is this an input or an output therefore still not 100% sure it is this panel that is defected, can anyone advise?
    Many thanks,
    Wayne
  4. Question Re: Audi 2.4 Fuse 5 Blows
    Apr 2009
    Hampshire
    Try taking the the climate control panel and check to see if there is any signs of corroded parts or if the pcb has any burnt tracks.
  5. Re: Audi 2.4 Fuse 5 Blows
    Oct 2010
    Plymouth
    I have removed the PCB and am struggling to see any signs of damage.
    Thanks, Wayne
  6. Thumbs up Re: Audi 2.4 Fuse 5 Blows
    Apr 2009
    Hampshire
    Hi Wayne
    It's sounds like you have found your fault in the climate pack. The only other thing I would check is the speed resistor behind the glove box for the fan speed and the motor. Disconnect both of those and then reconnect the climate pack and if fuse blows then go for a new display. Does the fuse state that it powers any thing else!!
  7. Re: Audi 2.4 Fuse 5 Blows
    Oct 2010
    Plymouth
    Could you kindly tell me where to locate and what size the speed resistor is, if the reisistor had burnt out, surely it would not cause the fuse to blow?
    Thanks,
    Wayne
  8. Re: Audi 2.4 Fuse 5 Blows
    Apr 2009
    Hampshire
    To locate the speed resistor and fan you need to remove the glovebox as it is all behind it.From memory some resistor packs are red. The speed resistor is normally bolted on the side of the heater ducts to help keep the resistor cool. It should have a plug with a few wires attached. Has the dash been removed at any stage and does it have an aftermarket stereo or hands free kit? These could have been tapped into vehicle wiring behind stereo!
    Sorry to bombard you with all these questions, it just gives me a better chance to help solve this problem.
  9. Re: Audi 2.4 Fuse 5 Blows
    Oct 2010
    Plymouth
    Dash does not appear to have been removed, std stereo and no sign of hands free kit.
    What I can confirm is that with socket D disconnected from the climate panel with fuse 5 in place the fuse does not blow and with the ignition on the fans run fast, the climate panel remains dead with no functioning.
    Based on this do you still see the speed resistor could be a possible cause, what type of DC motor is used, ie if the speed resistor had blown surely the climate panel would work but with no speed control. I am blowing a 10amp fuse so I something has to be shorted to earth.
    Let me have your feedback, the mornings are getting colder.
    Wayne
  10. Re: Audi 2.4 Fuse 5 Blows
    Apr 2009
    Hampshire
    you say the fans are still running fast. This is a good thing as when speed resistors fails they only run on full speed. I would definatly check that now. Diconnect it and put a new fuse in. Hopefully it wont blow the fuse. The fan is the only other componant which could blow that fuse without melting the insulation on the wires
    Please check both regardless as the fan could be damaging the resistor (ie dry bearings putting strain on the resistor).
    The speed resistor drops its voltage in line with the speed control on the display. The lower the speed the greater resistance is needed so when it packs up the only function available is full speed as its not resisted.
    I hope this helps before the cold weather sets in fully.
  1. Audi goes back to the future with commemorative quattro concept
    Last Post: 01-10-2010, 09:38 PM
  2. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  3. World Debut For The All New Audi A3 Cabriolet
  4. a4 multitronic problem
    By a4god2ulot in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2007, 02:52 PM
  5. Audi set for 12th record-breaking year in a row
    Last Post: 31-07-2007, 08:34 PM
