Thread: Possible battery issue ??
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
  1. Possible battery issue ??
    Oct 2010
    Worthing, West Sussex
    After a long weekend of being ill and having man flu I went to start my car and all I had was a clicking sound and that was about it, clearly the battery wasnt a happy camper.
    Only thing I can remember leaving on was my ipod classic 5th gen.. everything else was normal.
    I took it back to the place I bought it several weeks ago (After getting a mechanic friend to help jump start it), I mentioned about it possibly being a dud battery but they said it wasnt the battery as it was new before I bought it. They put it on charge and 2-3 days later it was 100% and everything seemed normal.
    I drove the car yesterday to work and all seemed ok, at lunch I was going to go out for a spin and the battery low indicator flashed up on screen briefly.
    I'm now worried that its a dud and I'll get stranded somewhere.
    I fixed up an old scuffy laptop I had (I use Macs at home and there is no client), an associate had a Virtual machine with an older version of the VCDS software on it 9.08 I think. I borrowed his cable and was able to grab some info out of it.
    I'm a VCDS newb but willing to give it a go
    I've done a scan and its found tons of stuff, much seemed to be related to low voltage..would it be appropriate to post somewhere else on these forums or here? Or should I just speak to the garage type chaps and let them know the findings?
    Audi A6 Allroad V6 3.0 272HP - Lighting Pack, BOSE Surround, DIS 7" Colour, MMI Navigation plus with MMI Touch, Audi Phonebox/Audi Connect, Advanced Key, Technology Pack, Parking Pack, LED Matrix w/High Beam assist, Privacy Glass
    Oct 2010
    Here And There
    Go for it. Post here
  3. Re: Possible battery issue ??
    May 2008
    Get the battery tested somewhere else. Find out its voltages when its running and been stood for a while. Check the battery drain level, all these can be done with a simple multimeter.
    Regarding VAGCOM, many of your faults will have been triggered by the flat battery so clear them all, drive the car and rescan it again then post up your findings.
  4. Re: Possible battery or electrics issue ??
    Oct 2010
    ok
    I'll try to keep it short, I dont think it has had the codes done for a while as there is quite a few older ones in it.
    There is a repeating theme which worries me..
    VCDS Version: Release 908.0
    Data version: 20090911
    Thursday,28,October,2010,20:19:33:13314
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
    61 62 6D 72 76 77
    Mileage: 92080km/57215miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 1010
    4F-Centr. Electr. II -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    61-Battery Regul. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: Malfunction 0010
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: Malfunction 1010
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F1 910 401 HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000AG 0040
    Revision: --H02--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    1 Fault Found:
    005662 - Glowplug for Cylinder 5 (Q15): Open Circuit
    P161E - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 91862 km
    Time Indication: 0
    Date: 2010.10.26
    Time: 08:09:35
    Freeze Frame:
    RPM: 903 /min
    Torque: 93.6 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.83 V
    Duty Cycle: 23.7 %
    Temperature: 16.2∞C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F1 910 156 A HW: 09L 927 156 A
    Component: AG6 09L 2.7 TDI 132 0020
    Revision: --H01--- Serial number: 4180031
    Coding: 0000002
    Shop #: WSC 02325 785 00200
    1 Fault Found:
    006246 - Powertrain Data Bus: Missing Messages
    P1866 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 25.0∞C
    T.B. Angle: 60.0∞
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
    Component: ESP 8.0 quattro H05 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 250
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.25
    Time: 07:56:23
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x42A2
    Hex Value: 0x0024
    Hex Value: 0x01AC
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000428670
    Coding: 0000147
    Shop #: WSC 00097 210 90086
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H39 0040
    2 Faults Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 0 km
    Time Indication: 0
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 8
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350EQ067680329
    Coding: 0001002
    Shop #: WSC 00097 210 90088
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H03 0050
    2 Faults Found:
    01327 - Control Module for Parking Aid (J446)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 6
    Reset counter: 217
    Mileage: 88363 km
    Time Indication: 0
    Date: 2010.07.27
    Time: 13:07:35
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 249
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 J
    Component: KLIMABETAETIGUNGH12 0170
    Revision: 00000030 Serial number: 00000000265100
    Coding: 0001302
    No fault code found.
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 D HW: 4F0 907 279
    Component: ILM Fahrer H15 0190
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0011101
    Shop #: WSC 02335 785 00200
    Part No: 4F2 910 113
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH12 0090
    Coding: 00141886
    Shop #: WSC 02335
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91840 km
    Time Indication: 0
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8113452
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:19:31
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0Y6R8X
    Coding: 0013381
    1 Fault Found:
    02095 - Component Protection Active
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenks‰ulenmodul H07 0230
    Revision: 00H07000 Serial number: 90026061290021
    Coding: 0102142
    Shop #: WSC 02323 785 00200
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 9
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:20:27
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 6
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:19:32
    01426 - Controls in Steering Wheel (E221)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 0 km
    Time Indication: 0
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
    Component: KOMBIINSTR. M73 H17 0660
    Revision: 00400000 Serial number: 4PX11P956
    Coding: 2049443
    Shop #: WSC 00011 888 96745
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 1300806507815E
    Coding: ECFE53C41B3106
    4 Faults Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 232
    Mileage: 89490 km
    Time Indication: 0
    Date: 2010.10.09
    Time: 17:50:11
    00463 - Control Module for Digital Sound Package (J525)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 227
    Mileage: 89490 km
    Time Indication: 0
    Date: 2010.10.09
    Time: 17:54:23
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 232
    Mileage: 90250 km
    Time Indication: 0
    Date: 2010.10.12
    Time: 17:09:10
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:19:33
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H47 1060
    Revision: 00000000 Serial number: 364EY067559390
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:18:30
    Freeze Frame:
    Hex Value: 0x4CC4
    Hex Value: 0x2295
    Hex Value: 0x0040
    02927 - DVD Read Error
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 7
    Reset counter: 240
    Mileage: 88393 km
    Time Indication: 0
    Date: 2005.09.26
    Time: 06:11:34
    Freeze Frame:
    Hex Value: 0x4CBA
    Hex Value: 0xD14C
    Hex Value: 0x0401
    Hex Value: 0x0000
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00000000 Serial number: `
    Coding: 0003706
    Shop #: WSC 02327 785 00200
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01013194620000
    Coding: 3154683
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:39:25
    Address 47: Sound System Labels: 4F0-910-223-BO.lbl
    Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
    Component: DSP-High C6 H09 0240
    Revision: PROD_01 Serial number: 00000000218522
    Coding: 0000113
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 18:09:58
    Freeze Frame:
    Voltage: 8.30 V
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000235445
    Coding: 0001103
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91840 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:19:00
    Freeze Frame:
    Voltage: 7.000 V
    Temperature: 15.0∞C
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 249
    Time Indication: 0
    Freeze Frame:
    Voltage: 6.200 V
    Temperature: 14.0∞C
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91840 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:19:00
    Freeze Frame:
    Voltage: 8.600 V
    Temperature: 14.0∞C
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00000000 Serial number: 7X
    Coding: 0003706
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 A HW: 4F0 907 801
    Component: EPB CA3C0040 H03 0040
    Revision: --H03---
    Coding: 0000521
    Shop #: WSC 02324 785 00200
    1 Fault Found:
    02443 - Control Head
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 250
    Time Indication: 0
    Freeze Frame:
    Voltage: 5.07 V
    Count: 40
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 E
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 352ES067652645
    Coding: 0000001
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 253
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 15:06:43
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 210
    Reset counter: 253
    Mileage: 88363 km
    Time Indication: 0
    Date: 2010.07.31
    Time: 01:07:07
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000029195
    Shop #: WSC 00097 097 55744
    Part No: 4F0 915 105 D
    Component: von VA0 2605080339
    Coding: 344630393135313035442056413032363035303830333339
    Shop #: WSC 00000 384 00290
    5 Faults Found:
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 127
    Mileage: 61543 km
    Time Indication: 0
    Date: 2009.05.15
    Time: 15:38:21
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 78
    Mileage: 88370 km
    Time Indication: 0
    Date: 2010.08.02
    Time: 01:49:14
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 25
    Mileage: 90654 km
    Time Indication: 0
    Date: 2010.10.17
    Time: 10:31:44
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 91972 km
    Time Indication: 0
    Date: 2010.10.27
    Time: 17:57:04
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:19:15
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0003114
    Address 6D: Trunk Elect. Labels: Redir Fail!
    Part No SW: 4F9 910 591 HW: 4F9 827 851 F
    Component: ValeoHeckdeckel H24 0290
    Revision: --H24001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    Part No: 4F9 910 592
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0003114
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 E HW: 4F0 919 283 E
    Component: Parkhilfe 8-Kan H12 0030
    Revision: 00H12000 Serial number: 11820613500201
    Coding: 0201116
    Shop #: WSC 131071 1023 2097151
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 0 km
    Time Indication: 0
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H18 1130
    Revision: 00000000 Serial number: 00000005128882
    Coding: 0010920
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 249
    Mileage: 91843 km
    Time Indication: 0
    Date: 2010.10.23
    Time: 13:19:46
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 249
    Thursday,28,October,2010,20:21:43:13314
    Control Module Part Number: 4F0 910 468 A
    Component and/or Version: Gateway H11 0070
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(High/D3) OK OK
    0E-Media Player 1 OK OK
    77-Telephone OK OK
    47-Sound System OK OK
    56-Radio OK OK
    37-Navigation OK OK
    According to a test I did (there was some tick boxes to show up to 12 elements, I'm a newb remember) the battery showed 70% which is a worry, I wasnt able to export the data for some reason, I'll grab a screen shot next time.
    Any help offered would be appreciated.
  5. Re: Possible battery issue ??
    Oct 2010
    Quote Originally Posted by Issac Hunt View Post
    14 and a bit volts when engine running, last time I checked the battery was around the 12.4x volt mark idle.
    Will try to figure out how to clear the faults and try again, I'll have some time this weekend. Alas I need the car for work so keen for it not to die. got a 40 mile run into work tomorrow hopefully can get a bit fo a charge in it.
  6. Re: Possible battery issue ??
    May 2008
    Clear all the faults, drive it and start again. Its the only way you'll make any progress with that huge list as the battery problem will have caused many of them.
    The battery meter isnt know for being 100% accurate. I'd check the battery drain and if possible have it load tested by a garage who know what they are doing!
  7. Re: Possible battery issue ??
    If MMI version is an older one, then the radio can stay on and draw power from battery when car is parked, see this service bulletin - http://www.fileden.com/files/2007/3/...b.91-07-13.pdf, and update to latest MMI version, which updates radio to fix fault. I had same problem and this fixed it, nothing to do with battery, it was a software fault that was causing the battery to drain.
  8. Re: Possible battery issue ??
    Oct 2010
    I'm smiling now, but I wasn't a couple of hours ago, battery was dead as a horrible dead thing.
    The wife called the garage as I was on the road, had to use her car, thank god she was off this week for half term.
    She called them and was uttering the immortal words "He's not happy, feels let down" etc etc..
    The garage are sending somebody to collect the car today. Given the fact the battery was given a pretty healthy charge, I have only done 40 mile plus journey's since then, bar a single instance of turning it around in a car park for the windscreen to be replaced, I can only assume the battery or charging circuit is crapped out.
    Alternator "appears" to charge the battery while the engine is running, pushing 14+ volts through it, not had a chance to measure the drain yet though.
    I'll report back as an when something happens.
  9. Re: Possible battery issue ??
    Oct 2010
    Quote Originally Posted by singhl View Post
    Thanks,
    I think I'm running the latest version now, 5570 was updated a couple of weeks ago. I did kind of think my ipod might have caused it too, but its not been connected for over a week now.
    If it does prove to be battery then I'll be a bit concerned as I'll have little faith in the garage/dealer I got it from. I note that my car still has not been picked up from my house though!!..
  10. Re: Possible battery issue ??
    Jul 2010
    Peterborough
    Did they collect it? What's the verdict?
  1. How To Remove battery without removing windscreen cowling & drain plenum, inc TDi
    By cazyp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2014, 03:03 PM
  2. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  3. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  4. Please Help Battery + Climate Control Unit + Engine + What's next?
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2009, 07:39 PM
  5. Battery drains overnight
    By Jonse123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2008, 01:53 PM
