Thread: auto gearbox fault
  1. auto gearbox fault
    Oct 2010
    maldon uk
    hi there have just brought a a4 1996 tdi auto 120k miles which has a slight problem with the box
    What happens is when i start the car and select R the car dips down and begins to move fine,
    when i select D the car does nothing for about 2-3 mins then dips down and begins to move,
    if i rev the car hardish then it will find the gear in about 1 min when the car becomes warm there is not a problem would anyone have any ideas what could be wrong cheers
  2. Re: auto gearbox fault
    Oct 2010
    manchester, uk
    First thing I would check is the fluid level in the box.
  3. Re: auto gearbox fault
    Apr 2009
    Somewhere....Over The StrongBow
    Things might improve if you get the box
    flushed and replace the filter.
    Regards
    Jim
  4. Re: auto gearbox fault
    Oct 2010
    maldon uk
    yes was going to try that have just got a new filter now just got to get the oil to suit
  1. Audi A6 VagCom Scan Results.
    By cwilding in forum VCDS - Help Requests
    Last Post: 19-11-2010, 10:19 PM
  2. Question what does this mean
    By mango in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-10-2010, 11:18 AM
  3. gearbox transmission fault A4 SE Auto Tiptronic
    By bwfcboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2010, 08:23 AM
  4. Gearbox oil level
    By mowjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 13-08-2009, 01:11 AM
  5. Vw Sharan Auto Gearbox Fault,running In Safe Mode ?
    By mck.motors in forum Archive posts
    Last Post: 10-10-2007, 10:54 PM
