Thread: Brake Light Switch
  1. Brake Light Switch
    Dec 2007
    Hi All,
    Apologies if this is posted elsewhere but searched forum and could not find anything. My issue is with my brake light switch and instruction on how to properly install. The issue arose when I noticed my brake lights were intermittently staying on and the glow plug was flashing on the console. I decided to try changing the brake light switch as a resolution. The problem is I must be doing something wrong as I am now on my 3rd switch! From reading up on the net it seems like these switches are a once off deal and you need to buy a new one if you screw up the install
    After first attempt had to push brake in more than usual to get lights to come on, second attempt, lights stayed on all the time regardless of brake peda position. As result of this fiddling around with the brake light switch my ESP, ABS and Glow plug lights are now ALL on !!
    The following is the procedure I followed, if anyone can tell me where I’m going wrong I would greatly appreciate it, from what I gather it’s a pretty straight forward job so beginning to feel like a total klutz
    My car is a 2003 A4 B6 1.9 TDi
    • Remove old switch
    • Unlock new switch (they came already unlocked)
    • Push brake pedal to floor
    • Insert new switch at 45 degree angle
    • Pull brake out slowly all the way while holding switch firmly in place (switch clicks several times)
    • Rotate switch into position
  2. Re: Brake Light Switch
    Jan 2009
    towcester northants
    i thought they were modified?
    all the new switches ive fitted are genuine and thet just turn into posistion no peeing around no more
  3. Re: Brake Light Switch
    Dec 2007
    Hi, thanks for your reply, the switch is the same as the akward (D type) one in this procedure for doing the install on a vw. This is the actual procedure i followed, only difference i noticed in the Audi is there are two similar switches to the top left hand side of the brake pedal, I had to remove the connector to figure out which one was for the brake lights, have no idea what the other one is for but they look the same.
    http://forums.vwvortex.com/showthread.php?1158315
  4. Re: Brake Light Switch
    Jul 2009
    Belgium
    if you get the new swich dont push the brake pedal during the instalation just leave the brake switch i send you a picture with the new switch named as (A) and the old switch named as (B) if you get the new switch dont push down the brake pedal and dont do any think to the switch just instal it {open the file with paint and change the format} the other switch next with 2 wires conection is for cluch pedal
  5. Re: Brake Light Switch
    Dec 2007
    Thank you for your reply, When i open this picture in paint or image viewer its very small and I cant really see anything, would it be possible for you to send me a larger image, if you have trouble posting it you could email it to me at nmgartland@gmail.com, many thanks,
    Nigel
  6. Re: Brake Light Switch
    Jun 2008
    Have literally just finished doing one.
    So far as I can see there are two ways of doing it but the key point is not to turn the body of the switch (which also locks the plunger switch) with the pedal depressed...
    So either:
    Ensure plunger is extended (you can check this by pushing it in & allowing spring to extend it again).
    Leave pedal in "up" position - gently locate switch into keyed slot then turn to lock.
    or:
    Depress brake pedal & hold down - gently locate switch into keyed slot then hold in place & gently release pedal. Only once pedal released turn to lock.
    I performed this a couple of times without sucess (or damage which is possible if you do not move the plunger when it is locked) because the brake lights still did not work. However I eventually found I had simply not turned the switch body enough!
    Hope this helps
  7. Re: Brake Light Switch
    Dec 2007
    Hi All , just to get back on this, I removed the switch and tried the procedure all over again and this time it worked perfectly, I must not have been turning it properly into place, thank you all for your help !
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  3. Please Help Green brake light switch
    By JayWorm in forum Golf MK4 - 1999 - 2004
    Last Post: 02-05-2009, 04:45 PM
  4. Brake light switch problems?
    By sparkykink in forum Ibiza - Cordoba
    Last Post: 11-07-2007, 11:29 PM
  5. Audi A4 Brake light problem
    By agriffiths in forum Archive posts
    Last Post: 22-12-2006, 02:10 PM
