Thread: gt engine not starting
  1. gt engine not starting
    Mar 2006
    South Queensferry
    ok im going to try and make this as easy as i can....
    i converted my polo from a spi to a gt mpi, what i got was engine, box, engine harness, ecu, relays, fusebox, driveshafts, coil pack, injectors, inlet manifold etc...
    i never got the rad water bottle, in car wiring loom, or charcoal filter..
    my problem... when i turn the ignition on, the fuel pump does not come on, but i tried firing it up anyway and there is no spark!!!
    i took a direct feed from the ignition switch to the back of the fuel pump relay, now the fuel pump comes on, but then doesnt kick off like it should do, tried starting it, still no spark, and stunk of petrol...
    any ideas anyone please, i have been stuck with this problem for a couple of days now and is doing my head in
    cheers
    john
    Feb 2006
    Nottingham
    for your fuel pump problem fix a switch in the live line to the pump,as and when you want it?
  1. Engine Fans Start Up after Engine is Switched off??
    By batman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2009, 02:15 PM
  2. Engine rev's rising and falling when starting
    By blocko in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2007, 12:10 AM
  3. engine drop - engine mountng bolts sheer
    By shazzander in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-04-2007, 03:29 PM
  4. Engine starting fault after timing belt change
    By MrPassat in forum Chat - Completely Off Topic
    Last Post: 18-02-2007, 11:10 PM
  5. slow hot starting on tdi engine
    By mikesvw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-02-2006, 07:20 PM
