Thread: 53 Alhambra SE TDI 130 Electrical Problem
Hybrid View
  1. 53 Alhambra SE TDI 130 Electrical Problem
    Dec 2008
    This problem occurred the other day, it had been raining heavily and I had been driving all morning. I parked the car for about 10 mins then started it and drove off. The following things happened....
    1. ABS light on
    2. Brake warning light flashing (brakes work but no ABS)
    3. No power at all to heating climatronic
    4. Temperature display changed from degrees F to C
    5. Fuel level and miles left of fuel wont stay constant
    6. No speedometer or miles clocking up
    7. No indicators (but hazards work)
    I have since checked all fuses they are fine. Checked relays they look fine but I do not know what each one controls and can not find this info online. Have checked fuses and wires at the battery and they are fine. Cleaned all terminals that I can see. There does not appear to be any moisture or water near wires.
    Any suggestions would be greatly appreciated. John
  2. Re: 53 Alhambra SE TDI 130 Electrical Problem
    Dec 2008
    For anyone who has the problem above...................
    Local mechanic found it to be a blown brake fuse. This was replaced along with the brake switch and all working as it should!
  3. Re: 53 Alhambra SE TDI 130 Electrical Problem
    Nov 2008
    folkestone.kent
    thought you had checked the fuses ? a least you know which fuse to pull to stop the miles clocking up...................
  1. Climate control - electrical problem - help needed!
    By JohnHighfield in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-10-2010, 09:17 PM
  2. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  3. Question Fit Montreal Wheels to GT TDI 130
    By Ben Jones in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2008, 10:34 AM
  4. VW Passat 130 TDi turbo problem
    By Timbo in forum Archive posts
    Last Post: 01-12-2006, 03:46 PM
  5. Passat 130 TDI turbo problem
    By Timbo in forum Passat - Archive Topics
    Last Post: 22-07-2006, 11:55 AM
