Thread: Rear window won't go up - not usual symptons
Results 1 to 9 of 9
  1. Rear window won't go up - not usual symptons
    Oct 2010
    Northwich, England
    I have a 2004 avant and the rear drivers window won't go up. I have taken the door apart and removed the motor to see if it's the regulator but even when the motor is free it only goes down, not up which I assume is a swithcing problem somewhere(I have tried the rear window switch and the main window contrcoller swithc). Everything else in the car works fine, just this one window.
    I have read somewhere that a unit under the passenger seat can get water ingress but the cars parked in the garage most of the time and for the past 2 years so can't see how it can be wet, especially when the carpet doesn't feel wet.
    Your ideas would be appreciated.
    Many Thanks
    Colin
  2. Re: Rear window won't go up - not usual symptons
    Ayrshire, Scotland
    18 Post(s)
    does it go up if you pull the glass up while using the switch at the same time? or is the switch dead as in nothing happens at all? It may be broken sliders, common on the front doors.
    i don't think it will be the convenuence module under the seat as you will have many problems not just the window, but check for water under the battery tray just in case.
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Rear window won't go up - not usual symptons
    Mar 2008
    High Wycombe
    common causes of the window not winding up are the plastic sliders cracking (like my front passenger window), or a wire breaking in the rubber boot between the door and the hinge (like my offside rear window).
    usually the broken sliders let it wind up a bit until it sticks, which makes it wind down a bit.
    the broken wire usually seems to stop it working at all.
    As Andy says, it doesn't sound like the ccm, but it's always a good idea to shine a torch down the side of the battery to see if there's any water down there.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: Rear window won't go up - not usual symptons
    Oct 2010
    Northwich, England
    I'll have a look for water when I get home.
    I am confident the issue isn't related to the window mechanism, when I remove the motor from it's housing nothing happens when the switch is moved up but it does move down. it's an electrical issue somewhere.
    Colin
  5. Re: Rear window won't go up - not usual symptons
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by Colin A6 Avant View Post
    Colin
    Ok, as Nickpicks suggests, check wiring in the rubber between the door and the body, the rubber sleeve "should" pull off the car body toward the door allowing a look inside at the wiring. the multiplug should also disconnect at the body if needed
    Andy
  6. Re: Rear window won't go up - not usual symptons
    Check the signal on Pin 3 and 4 on the motor, one should be for up and one for down. Regards Peter
  7. Re: Rear window won't go up - not usual symptons
    Oct 2010
    Northwich, England
    Sorted it.
    Turns out it was the connection on the switch on the rear door, I haven't a clue how it came loose but now it's secure and working.
    Thanks for the posts.
    Colin
  8. Re: Rear window won't go up - not usual symptons
    Sorry to jump on your thread but mine is also faulty. It goes half way up & jams. Seem to be going up at a slight angle & if you keep it straight, it's fine. Nickpicks says the sliders break, which sounds like my fault. Does anybody know if these can these be bought on their own, or do I need to buy a complete regulator?? Thanks
  9. Re: Rear window won't go up - not usual symptons
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by type49 View Post
    Hi Read quite a common problem with the slider breaking.
    read this thread, there are many others but it will give an insite and may describe what problems you are having:
    https://www.vwaudiforum.co.uk/forum/s...ghlight=window
    Basically if it is the slider you need, part no 4B0 837 463B (Ł2.20 + VAT) from an Audi Dealer
    regards
    Andy
  1. Please Help Mk3 Gti - Loose rear passenger window
    By aris in forum Golf MK3 - 1993 - 1999
    Last Post: 19-04-2010, 08:54 AM
  2. Rear window washer
    By makemineamythos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2010, 08:56 PM
  3. Passenger (rear) window stuck.
    By Trillock in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2010, 07:45 PM
  4. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  5. Rear Window Wiper
    By High-Voltage in forum Golf MK3 - 1993 - 1999
    Last Post: 05-05-2008, 02:48 PM
