Thread: Cold Start Issues
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. Cold Start Issues
    Recently purchased an 2001 (Y) Audi A3 TDI
    Since I’ve had it, the cold start in the morning has been getting progressively worse. It's reached a stage today where it's almost as if the battery is about to die but suddenly fires into life. I let the glow plug light disappear before attempting to start.
    On a side not, once I’ve run the car and its warm, if I switch it off and back to ignition, the glow plug light takes ages to disappear but start with no struggle.
    After some read up, it seems it could be starter motor, glow plugs or a temp sensor. Before attempting anything, I just wanted to gauge a few opinions?
    Many thanks
  2. Re: Cold Start Issues
    Mar 2008
    High Wycombe
    To me, it sounds like the glow plugs need replacing, although I'm not an expert on Audi TDI engines, that's what fixed it on several other diesels my dad has owned.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Cold Start Issues
    134 Post(s)
    2009 Post(s)
    More than likely you need a new coolant temperature sensor but have a fault code read done first. It is also possible that it needs new glow plugs as Nick says. What is the cars engine type code?
  4. Re: Cold Start Issues
    I gave the car a full service yesterday including plugs and although making a slight difference, it still struggles with the first start of the day.
    I'm not 100% sure about engine type, how could i check?
  5. Re: Cold Start Issues
    134 Post(s)
    2009 Post(s)
    Service book , log book, data sticker, cam cover.
  6. Re: Cold Start Issues
    Mar 2009
    I'm sure it's glow plugs.Glow plugs are only used to start a diesel engine unlike spark plugs which work on every stroke
  7. Re: Cold Start Issues
    134 Post(s)
    2009 Post(s)
    Glow plugs are run as part of the running strategy when cold until the ECU decides to turn them off.
  8. Re: Cold Start Issues
    The engine code is ASV.
    I've been away for the weekend which has meant the car has been sitting there for 2 days. When i came to start it, it took around 10-15 of slow cranking before the engine finally started.
    Glow plugs were changed during the service so i can definately rule them out i think.
    Is the coolant sensor a difficult expensive replacement? Im considering replacing that before spending money for it to be put on a diagnostic if its a fairly common fault.
  9. Re: Cold Start Issues
    134 Post(s)
    2009 Post(s)
    It is THE most common fault and easy to chnage, only do it when the engine is cold. It is in the water housing on the end of the head over the gearbox.
  10. Re: Cold Start Issues
    Would it make a difference that i get no warning light for the coolant system at all?
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Please Help Golf 5 TDI 2.0 won't start / random electrical issues
    By Systemshock in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2010, 06:20 AM
  3. GOLF GT TDI (150) 2002 Intermittent Poor Start
    By JamesVW in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2010, 04:53 PM
  4. AEH cold start problem
    By babariba in forum Golf MK4 - 1999 - 2004
    Last Post: 01-03-2008, 09:20 PM
  5. audi coupe cold start ???
    By sox in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 08-01-2008, 08:53 PM
