Thread: Damp smell
  1. Damp smell
    Apr 2007
    When I start up there is a damp smell coming from the vents, not sure what the problem is. Just had full service and aircon drained, cleaned and re-charged.
    Any Ideas welcome.
    Cheers Pricey.
    Dec 2006
    Open the bonnet... remove the full plastic tray which is above the battery.. then to the top right hand side (passenger side) you will see a black box.. this is where the pollen filter is..
    Just take it out and make sure its dry.. also check around that area for any build up of water... also theres a little drain hose.. ensure its cliped into the pollen filter hose (around the outside.
    RickT
    Apr 2007
    Cheers will check tomorrow, but according to invoice the pollen filter was changed 2 weeks ago.
    Cheers again.
    Mar 2007
    Cumbria
    I would also check the drain hole in the plenum chamber this under the battery,also the drain tube for the heater box this located somewhere on the bulkhead..
    Dec 2006
    its always worth a look around that area as its common for water to collate....
    One thing to check.. lift the passenger mat and make sure its dry under the mat..
    RickT
    Apr 2007
    Hampshire
    Oh, and make sure you've had a shower..................Just kidding!! If its coming through the vents then something in the air system isnt draining properly since they fiddled under your bonnet, check the above suggestions, it wont be in the cabin.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
    Feb 2007
    in a mornign, wehn i start my car a blast of water vapour coems out of my windscreen ventand steams it up, but then it only take sa few seconds and it clears it again.
    could this be a drainage problem ? i always put it down to air con, its not a problem I just wondered after reading this thread.
    Apr 2007
    Hampshire
    No this will just be condensation in the air pipes, totally normal when its humid.
  1. Damp smell coming from blowers
    By ayresy101 in forum Passat - Archive Topics
    Last Post: 29-08-2007, 01:59 AM
  2. Damp Footwell
    By Mafu in forum Toledo
    Last Post: 28-07-2007, 08:20 AM
  3. A3 Air Con - Bad Smell
    By a33322 in forum Archive posts
    Last Post: 14-05-2007, 10:15 PM
  4. Very damp carpet...
    By AsaTDi in forum Passat - Archive Topics
    Last Post: 26-12-2006, 01:25 PM
  5. damp carpets-front passenger side
    By laujen in forum Passat - Archive Topics
    Last Post: 20-07-2006, 11:49 PM
