Thread: Heater Blower Motor / resistor
Results 1 to 10 of 17
  1. Heater Blower Motor / resistor
    Blueirv Guest
    I know there are various posts concerning heater blower motor problems and many refer to the need to replace a resistor.
    How do I know if the problem is the resistor or if it is the motor itself?
    I have removed the glove box and the motor and I cannot see a separate resistor - is it integral?
    Audi A4 Avant 1997 2.8 SE with climate control.
    Alex
  2. Re: Heater Blower Motor / resistor
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Since you have Climate Control, the fan is controlled by that. Without, and you will have a Resistor. If the motor isn`t running try a direct power supply to motor. This will give you an idea where problem lies.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Heater Blower Motor / resistor
    Blueirv Guest
    Hi Alan
    I have now done this and the motor is running.
    If it's not the resistor or the motor any ideas what else it might be?
    Alex
  4. Re: Heater Blower Motor / resistor
    134 Post(s)
    2020 Post(s)
    If the motor stops and starts and often comes to life again after going over a bump, the brushes are worn and need replacing or fit a new motor,
  5. Re: Heater Blower Motor / resistor
    Blueirv Guest
    The motor wasn't running at all. I removed it from the car and attached it to a DC supply and it runs fine. Could this still be the brushes?
  6. Re: Heater Blower Motor / resistor
    Mar 2010
    Plymouth, England
    Quote Originally Posted by Blueirv View Post
    Unlikely. If you've got any sort of meter check and see if the motor is being supplied power when it's installed.
    '96 A4 Avant 1.8 - Mine
    '02 Fabia 1.9TDI - Mrs's
  7. Re: Heater Blower Motor / resistor
    Blueirv Guest
    I've now reattached the motor to the car after testing and it is currently running OK.
    This may indicate that it is indeed an intermittent problem and could be down to the brushes.
    The unit is sealed and it is difficult to actually get to the motor to replace the brushes.
    It is part number 8D2820021 and it looks like this:
  8. Re: Heater Blower Motor / resistor
    Oct 2010
    droitwich spa
    hi, the motor isnt sealed, there are 3 rubber bungs
    press these in and down and the lot will seperate.
    then release the two clips holding the springs that hold the brushes
    unsolder the old brushes, fit new brushes and solder in place.
    re fit
    job done
  9. Re: Heater Blower Motor / resistor
    Feb 2010
    Plymouth
    Quote Originally Posted by rob_a4 View Post
    re fit
    job done
    I got some pictures of this if it will help any one out in the future.
  10. Re: Heater Blower Motor / resistor
    Blueirv Guest
    Thanks all who offered advice. Bought brushes from eBay and replaced them in about 30 mins. Blower working perfectly and at the cost of a tenner. If I can help any others let me know.
    Alex
  1. Question Heater Fan Blower problems
    By A4Ecosse in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2010, 11:02 PM
  2. How To Octavia Mk1 heater blower swap.
    By Pastedavid in forum Octavia
    Last Post: 17-02-2010, 05:08 PM
  3. Heater Blower Motor or something else?
    By Audi 80 Man in forum 80 - 90
    Last Post: 08-01-2008, 06:54 PM
  4. Heater core replacement 93 passat VR6
    By farmhemi in forum Passat - Archive Topics
    Last Post: 05-01-2008, 04:25 AM
  5. Heater blower problem
    By knight A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-01-2008, 08:26 PM
