Thread: air bag light
  1. air bag light
    ju1es1970 Guest
    Hi guys.
    got a problem with my air bag light.
    when i start the car the air bag comes on and stays on for about 2-3 minutes then it goes off.
    It has just started doing this and dont understand y.Any ideas any1?
    any help would be much appreceiated.
    Cheers.
  2. Re: air bag light
    Apr 2009
    Hampshire
    The airbag light should come on for a few secounds after car is started but should go out as the car does a self check of the restraint system every time you turn the key to ignition.
    It sounds like the car logs a fault and after you start to drive it corrects its self. Possible steering wheel squib which connects drivers airbag to wireing harness.(behind steering wheel).
    The only other thing it could be is the wiring to the seatbelt pre-tensioners on the drivers seat.
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. Air Bag light.
    By goodwoodys in forum VCDS - General Questions
    Last Post: 16-02-2008, 09:26 PM
  4. air bag warning light permanently on
    By powerbike in forum Octavia
    Last Post: 23-11-2007, 04:25 PM
  5. EMS Light intermittent - Air Mass Meter/breather pipe
    By tusken in forum Audi A3 - Archive Topics
    Last Post: 03-05-2007, 12:00 AM
