Thread: Cold running engine, excess oil from inlet manifold
  1. Cold running engine, excess oil from inlet manifold
    I have a couple of questions relating to my 1.9TDI unit.
    My engine always runs at 65 - 70c, is this normal? As I though norm operating temps are around 85 - 90c
    I also have alot of oil which seems to be leaking from the manifold to intercooler pipe - have been told that this maybe fue to my turbo being warn and letting oil through? Really hope not as I has the turbo ispected and re-balanced at turbo technics at 115k (now done 135k)
    The engine seems to be getting noiser and a little rougher too - peroformance seems to have suffered too
    Has anybody got any ideas what could be wrong? I generally have my oil changed every 8k which has recently been done.
    - Might be worth mentionin that I have a de-cat fitted and have blanked my EGR off too
    Any advice would be more than welcome
    Audi A4 1.9TDI Quattro Sport in Black - Remap, Turbo Dynamics Re-Balanced Turbo, De-Cat, EGR Mod, K&N Panel filter, RS4 RARB, S4 Track Rod Ends, Koni FSD's, 320m DTM brakes up front and retro fit cruise.
    Factory fit - HID's (Osram Intense 5k's fitted), Bose, Comfort Pack, Folding Mirrors, Ambient Light pack.
  2. Re: Cold running engine, excess oil from inlet manifold
    May 2008
    Quote Originally Posted by borabear View Post
    No it should be at 90 when warmed up. I'd suspect the thermostat and/or the coolant temp sensor.
  3. Re: Cold running engine, excess oil from inlet manifold
    Feb 2010
    Sudbury
    Ditto to Issac's comment but try the sensor first as the thermostat would be fully open after a few miles drive, so the coolant would then be at running temp. Yes bang on 90 degrees is what you should see on the gauge. Have fun as they are pig to get at but only a 5 min job.
  4. Re: Cold running engine, excess oil from inlet manifold
    Quote Originally Posted by RON MOODY View Post
    So this has nothing to do with me blanking off the EGR? I thought with the hot exhaust gas not being recirced it might of brought the engine temp down
    So what are the ramifcations of havin a duff therosat? is it damaging my engine?
    What about the oil in the manifold?
    Rich
  5. Re: Cold running engine, excess oil from inlet manifold
    Oct 2012
    shoreham by sea
    Anymore info?????
    Progress????
    Sounds like my motor!
  1. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  2. Please Help Engine Light, Running Slighty Rough....
    By le19h in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-09-2009, 01:03 PM
  3. Cleaning the Intake Manifold....
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 07:51 PM
