Thread: A4 2.0 tdi sline loss of power and bad ticking noise
  1. A4 2.0 tdi sline loss of power and bad ticking noise
    Oct 2010
    norwich england
    i recently had a new air con compressor fitted to my car! the next morning driving to work it jerked as i accelorated then sort of went into a safe mode with no turbo power, wen i stopped the engine was also ticking quite bad??? i took to the garage i brought it from 2 years previous who checked it on the computer.
    the fault was an engine mount sensor this was checked and reset but the problem never went away. they kept the car for 2 weeks with no joy even an audi tech said he never heard anything like this? i ended up just collecting the car as i was told there was nothing they could do??? can anyone help?? thanks
  2. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    chester
    17 Post(s)
    gonna need more specific info if you want some help,try and locate where the tickings coming from,did they replace the engine mount,what codes were stored?is it still in limp mode?
  3. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    Oct 2010
    norwich england
    i dont know wat codes and they didnt replace the mount just reset the system! its still in limp mode they checked oil pressure which is fine as it sounds like there isnt any oil in it? ive read up about a comman fault with the timing gear? i will try and find out the codes etc etc thanks mate
  4. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    chester
    17 Post(s)
    I would certainly check the timing and the cambelt,get a full description of all the codes stored.
  5. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    Oct 2010
    norwich england
    found the reason! some of the old belt that hadnt been removed jammed the crankshaft pulley and made the belt slip but only 2 teeth on 1 cam!! the timing has now been put right and it seems there aint any more problems! :-)
  6. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    Pembrokeshire
    22 Post(s)
    that was lucky then. if it had slipped much more, the bill could have been immense.
  7. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    Oct 2010
    norwich england
    well the garage who put it right are sayin it could of damaged some roller things on the cam shafts and would have to remove the head to replace at a cost of like £1500 but im hoping on it aint done any damage! it dont sound any different to me but they are sayin its not sounding happy ?? hmmm not sure
  8. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    Pembrokeshire
    22 Post(s)
    if you are happy with it, then just put some gentle miles on it and see how it goes. if it gets noisey, take it back again and see what they think.
  9. Re: A4 2.0 tdi sline loss of power and bad ticking noise
    Oct 2010
    norwich england
    cheers mate! its done 107k and has always been a littlie noisey but ive heard most tdi's are at that age? but yeh im happy lol
  1. a4 tdi sport smoking bad
    By mickyd82 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-03-2010, 10:25 AM
  2. Question A4 2.5 tdi v6 poor starting & no power
    By boratdi130 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-10-2009, 08:10 AM
  3. A4 2.0 tdi 140 bhp questions/advice
    By Darlo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-08-2008, 04:55 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. A4 2.5tdi intermittent, then solid, power loss
    By rob7706 in forum Archive posts
    Last Post: 05-10-2006, 08:00 PM
