Thread: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
Results 1 to 10 of 11
  1. AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Jul 2007
    Chester
    I have AUDI A4 1.9TDI PD 130 – engine AWX. She just had cambelt changed.
    I believe RPM went up from 800 to 860 so I would like to check/adjust injection timing.
    I know how to check injection timing via VAG-COM (Measuring Blocks, group 4).
    I just wonder if there is any “how to” or “DIY” how to mechanically adjust timing. I only know that there are 3 bolts which secure the two parts of the pulley together – I would like to see any pictures where are these or so….
    Any help really appreciated!
    Thank you,
    Dan
    Audi TT 1.8T Quattro 225 - Sold , AUDI A4 1.9 TDI 130 AWX - now
  2. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I think your on about the Cam timing, not Point of Injection.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Apr 2009
    Think 860 is ok, has it lost power or is it smoking under acceleration?
    Setting injection timing is done at each injector, its quite involved but if your eager, Crasher has a how to on here somewhere.
    Regards
    Jim
  4. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Jul 2007
    Chester
    Quote Originally Posted by Alan02 View Post
    You might be right - it could be cam timing....any idea?
  5. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Jul 2007
    Chester
    Quote Originally Posted by yaman View Post
    Regards
    Jim
    I didn't realized any smoke, it runs as before though. I might have a bid higher consumption though...
  6. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    134 Post(s)
    2015 Post(s)
    The cam timing on a PD engine can only be set/checked using a locking plate in the crank pulley and a locking pin in the cam pulley which means stripping the front of the car down again. The “Tipex and pray” method should never be used.
  7. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Sep 2008
    chester
    17 Post(s)
    Who did the cambelt?did they lock they crank &cam sprocket?
  8. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Jul 2007
    Chester
    Quote Originally Posted by nevo View Post
    Yes they did, but probably they didn't check it with a vagcom.
    I have synchro angle on 1.1 (see below), however it needs to be 0 - will sort it tomorrow.
  9. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    134 Post(s)
    2015 Post(s)
    You CANNOT check the cam timing or Commencement Of Injection of a Pumpe Düse engine with VAG-COM!!!!!!!!!! It is set purely using the locking tools, only a VEP TDI can have its COI checked in Basic Settings.
    http://www.ross-tech.com/vag-scope/TDIGraph.html
    Read the note in bright red!
  10. Re: AUDI A4 1.9TDI PD - how to set Injection Timing after cambelt change
    Jul 2007
    Chester
    Probably I didn't write it clearly what I wanted to know...
    "You can check that your cam is in time with your crank shaft. Basically you are checking your timing belt installation is proper. This is adequately done by using crank and cam locking pins during installation, if the belt is kept properly tensioned. But the check is easily done, and can flag belt stretching or other problems.
    Go to measuring block 4, field 4, and check the value. It should be between -3 and +3, with zero being ideal.
    If it gets more negative than zero, your cranking time gets longer.
    You adjust the cam sprocket to make this adjustment."
  1. Audi e-tron spyder hybrid study goes live in paris
    Last Post: 01-10-2010, 09:34 PM
  2. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  3. A4 1.9tdi cambelt change.
    By shamo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2008, 07:37 PM
  4. New Audi A4 Cabriolet Range Update Bulletin
    Last Post: 09-11-2005, 08:37 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
