Thread: Sharan - Starnge air hissing from driver's footwell
  1. Question Sharan - Starnge air hissing from driver's footwell
    di4charles Guest
    I own a late 2001 VW Sharan (New Shape). Whenever I release the brake pedal I'm left with an air-like hissing noise eminating from the driver's footwell. I can make it go away if I give the gentlest tap on the brake pedal.
    I have had my brakes checked by a mechanic who can find nothing wrong (the noise never appears when he is around)! Indeed the car has just passed its MOT.
    Any thoughts? Some unimportant rubber boot or gaiter perhaps?
    A month later and things have moved on a bit. The air hissing noise is now constant and louder from the drivers footwell, except when I apply the brakes and it goes away. A mere tap on the brake pedal and I can make the noise go away until the next time I use the brakes. Is there a part with a diaphram that needs changing and if so, how do I access it?
    Please, somebody answer. My Sharan has driven 320k miles.
  2. Re: Sharan - Starnge air hissing from driver's footwell
    Dec 2007
    can be vacuem suck noise from the servo or noise from ecu pipe that lurks near the brake pedal or last thought a pipe going to heater system as that uses vac for flaps. its a case of getting your head in that area take the plastics off bottom of dash for better access
    Sharan 1999 1.9tdi 110 afn
  3. Re: Sharan - Strange air hissing from driver's footwell
    di4charles Guest
    Thanks for your reply. It turned out to be a leaking brake servo that required replacing.
  1. Water on drivers side footwell
    By GavinT in forum Golf MK5 - 2004 - 2009
    Last Post: 17-10-2010, 08:22 AM
  2. Sharan P REG drivers side window oddity
    By chally3 in forum Touran - Sharan - Caravelle
    Last Post: 17-05-2010, 01:25 PM
  3. water in drivers side footwell
    By baj25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2010, 04:48 PM
  4. Sharan - air con/help please 3 kids under 4 getting hot
    By elijah1 in forum Touran - Sharan - Caravelle
    Last Post: 31-05-2009, 04:13 PM
  5. Sharan footwell full of water...
    By 3narf in forum Touran - Sharan - Caravelle
    Last Post: 16-01-2008, 06:17 PM
