Thread: PCV/EGR Valve
  1. PCV/EGR Valve
    Jul 2007
    Co Durham
    Are the PCV (???Crankcase Ventilation) and EGR (Exhaust Gas Recirculation) valves the same or different things? What are the systems of a failing PCV valve - can it include hiher oil consumption and the emissions light coming on occasionally? Thanks
  2. Re: PCV/EGR Valve
    131 Post(s)
    1974 Post(s)
    Positive Crankcase Ventilation and Exhaust Gas Recirculation are two different emissions systems. Which engine are we dealing with?
  3. Re: PCV/EGR Valve
    Jul 2007
    Co Durham
    Awy 1.2
  4. Re: PCV/EGR Valve
    131 Post(s)
    1974 Post(s)
    The PCV system on the AWY has not given me any trouble yet but the EGR valves are a nuisance. I suggest you start with a fault code read.
  5. Re: PCV/EGR Valve
    May 2008
    Sorry to spoil the party, but....
    I have the VW Factory Service Manual printed off from vwerwin.
    It clearly says the following....
    Exhaust gas recirculation system
    The exhaust gas recirculation system was only fitted on engines with
    engine codes AZQ, BME.
    From 11/2005 the exhaust gas recirculation system will be discontinued
    on engines with engine code BME.
    Note
    The function and control of the exhaust gas recirculation system is
    checked by the engine control unit -J623- self-diagnosis.
    The exhaust gas recirculation valve -N18- with tapered valve tappet
    allows various cross sectional openings at different valve strokes.
    Pulsed control enables every conceivable valve position.
    I suggest you do not have an EGR valve.
    The excessive oil consumption was a feature of the AWY engine.
    That's why they used to sell the Polo with a bottle of oil in the boot!
  6. Re: PCV/EGR Valve
    131 Post(s)
    1974 Post(s)
    You are correct; the AWY does not have EGR. I was thinking AZQ as it was a 3 cylinder.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. EML comes on every few weeks with 3 errors
    By Dark Horse in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2010, 07:37 PM
  3. 1.8T Sheared exhaust valve
    By portmanteau in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-09-2009, 10:09 AM
  4. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
