Thread: xenon headlight fuse ??
Results 1 to 10 of 14
  1. xenon headlight fuse ??
    Dec 2009
    windygates, ecosse
    hi,
    went out to the car after work and proceeded to start car and then switch on lights, the DIS went through its check and highlighted that there was a lamp problem, checked my headlights and both of the xenon's are not working found that the main fuseboard has fuse 20/21 covering dipped main beam but there is no fuses, any ideas ? - surelly both xenon's have not gone @ same time, everything else on headlight is working fine - as always all help appreciated.
    thanks gary....
  2. Re: xenon headlight fuse ??
    Jan 2010
    Lincolnshire
    I have a similar problem with mine,when the engine is running and I switch the lights on the DIS tells me the off side light is out which it is but if I put the ignition on only then turn the lights on then both headlights come on voltage drop maybe??.
    Have you tried switching them on with just the ignition on?
    A6 3.0ltr v6.
    SE Quattro.
  3. Re: xenon headlight fuse ??
    Dec 2009
    windygates, ecosse
    the sidelights are fine and i get no warning message but as soon as i go to put headlights on I get the fault - full beam works but no xenon's - surely has to be fuse, they were both working fine this morning
  4. Re: xenon headlight fuse ??
    Jan 2010
    Lincolnshire
    Quote Originally Posted by Haggag01 View Post
    I would also say a blown fuse,but I`m no mechanic.
    A6 3.0ltr v6.
    SE Quattro.
  5. Re: xenon headlight fuse ??
    Dec 2009
    windygates, ecosse
    is there a secondary fusebox in the engine bay area ?
  6. Re: xenon headlight fuse ??
    Dec 2009
    windygates, ecosse
    have found that there are fuses at the side of the dashboard and they are intact, what was intresting was that when I selected headlight the leds on the switch were flashing - any ideas ?
    Gary...
  7. Re: xenon headlight fuse ??
    Jan 2010
    Lincolnshire
    Gary...
    Hi Gary,could it be a faulty switch? sorry I`m not more help mate.
    A6 3.0ltr v6.
    SE Quattro.
  8. Re: xenon headlight fuse ??
    Dec 2009
    windygates, ecosse
    been in contact with peter D - big thanks !!!! and it looks like we are @ the stalk, anyone changed this before ?
  9. Re: xenon headlight fuse ??
    Dec 2009
    windygates, ecosse
    well, it isnt the stalk was able to get a multimeter on fuse 20/21 and i have 12v at them
    so is it possible that the two gas discharge lamps have failed at the same time ?
    and can they be replaced and how ?
    thanks gary...
  10. Re: xenon headlight fuse ?? ** solved ***
    Dec 2009
    windygates, ecosse
    hello all,
    have been a bit of an ar@e here !!!!
    If I had taken a proper look at the headlights I would have realised that they were just bog standard halogens !!!
    The problem - both dipped beam halogen lamps 12v 55w G7's had went, replaced and all is fine in the world !!!
    Thanks to all - and especially Peter D
  1. Best headlight bulbs for blue Xenon look
    By jonsey24 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-06-2010, 07:13 PM
  2. Question Airbag fuse
    By pcplum in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-02-2010, 06:57 PM
  3. HEADLIGHT PROBLEMS!! - one works, one does not.. HID's
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2009, 12:54 PM
  4. Where's the fuse for the electric headlight motors?
    By alan.surry in forum Golf MK4 - 1999 - 2004
    Last Post: 27-01-2008, 02:54 PM
  5. Xenon Headlight Conversion
    By BigChris1984 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-12-2007, 10:10 PM
