Thread: Rear bearing help, Had to grind hub off!!
  1. Rear bearing help, Had to grind hub off!!
    Feb 2010
    Liverpool
    Evening all, Rear wheel bearing needs doing (a4 quattro 1.9tdi) Had to grind the bottom bolt and spacers off because it wasnt coming out at all and grind the track control arm balljoint in half!!, i think thats what it is, Maybe somebody can confirm, One end bolted to chassis, Other a balljoint on hub towards the rear of the car/hub, That wasnt moving, so i have it off, Whats the process, Is a press a must? Bearing are really bad even at 5mph.!!!
    Also, Where will i get a bottom bolt and bushes/spacers.... apart from the dealer?? Why is the word s t ealer censored??!!
    Thanks people..
    Audi A4 Quattro (AFN)
  2. Re: Rear bearing help, Had to grind hub off!!
    Apr 2009
    HOLY MOLY!!
    It must have been like a scene from "Texas Chainsaw Massacre" LOL
    All those bits and pieces are better got from VAG,..go on force yourself.
    The press is a better job, but can be done with pullers/vice.
    Regards
    Jim
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  3. New bentley continental supersports convertible
  4. renew wheel bearings without joint pain
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-12-2009, 10:10 AM
  5. Front Wheel Bearing replacement
    By tornadored7 in forum Archive posts
    Last Post: 30-08-2007, 09:05 PM
